ROBOSAPIEN SECRET: Automatic Robot Sentry
In “Listen” mode, your Robosapien will wait for over 2 hours before getting
bored and shutting down. You can “link in” the listen modes up to 14 times
using the regular P program,; the following is an example of how to make
your robot “guard” a hallway for hours and always stay in place.
Press S>
Select – Select – LeftTurn (Strike3 on the right controller side)
Select – Listen
Select – Select – Stop (Roar)
Select – Listen
Select – Select – RightTurn (Strike3 on the left controller side)
Select – Backwards
STOP
Press P
Press S> 14 times or until the robot says “Ooo! Uh-Huh!”
Robosapien will now enter a mode where he will wait against a wall and
strike anything that passes by, occasionally stepping back into place against
the wall. He will do this 42 times before finally stopping. Press STOP to
deactivate. Press P> to play again.
Change the S> reflex to the following for more in-your-face action.
Press S>
Select – Forwards
Select – Forwards
Backwards
STOP
P>
Robosapien will now awaken, come forward and attack, then return to his
place at the wall.
Many such programs are possible.
Have fun!
