ROBOSAPIEN PROGRAM FEATURE: Song and Dance Programming
Your RoboSapien has some limited singing and dancing skills. Power on your robot, wait until he finishes his wakeup, then enter the following…
Press P
Select – Select - TALKBACK
Select – R>
Select – S>
Select – L>
Select – R>
Select – S>
Select – L>
Select – R>
Select – L>
Select – R>
Select – L>
Select – R>
Select – Select - BURP
The robot will automatically execute an amusing short “rap” song. Press STOP to end, press P> to play again.
The default reaction sounds under the R>, S>, and L> can be reconfigured a variety of ways with the RoboSapiens’ other personality noises. For example, enter the following…
Press P
Select – L>
Select – L>
Select – S>
Select – S>
Select – S>
Select – L>
Select – L>
Select – S>
Select – S>
Select – S>
Select – R>
Select – R>
Select – L>
Select – Select - STOP
The robot will automatically sing another “song”. Press STOP to end, press P> to play again.
DANCING:
Once you have a beat you like, you can now program the reflexes with motions that will allow the robot to dance. With the last program still under the master program P, enter the following…
Press R>
Right Shoulder UP
Select – LEANFWD
Left Shoulder UP
Select – LEANBWD
Right Shoulder DOWN
Left Shoulder DOWN
Press STOP, or wait for the routine to finish, then enter the following…
Press S>
Select – LEANBWD
Select – LEANFWD
Select – LEANBWD
Select – LEANFWD
Left Forearm OUT
Right Forearm OUT
Press L>
Select – LEANFWD
Tilt RIGHT
Select – LEANBWD
Tilt LEFT
Right Forearm OUT
Left Forearm OUT
Press STOP, or wait for the routine to finish, then press P>. The robot will now go through a 40 second long dance routine.
To hear your original song again without erasing your reflex dance moves, press…
Select – P
If you want to change the beat or length, you can change your song without affecting your dance moves by pressing P and entering a new song (like the first song above for example).
In this way, you can easily enter a basic beat and edit dance moves in any pattern. Add LISTEN commands through your reflex steps to make the robot dance in beat to loud songs from your stereo. Add walk and turn commands to make him cover some dance-floor territory.
Many combinations are possible. Variations are encouraged.
Gabi12's picture
How to do Select Select talkback
