What's the best motor controller for tiny robot
3 posts / 0 new
Vellywio
Vellywio's picture
I want to build a tiny obstacle avoiding robot using a 3v coreless DC motor. I've been using this L293D to control 5V motors and up, but I can't seem to find a motor controller that works with motors below 5V anywhere. I also have 3V two-step motors, but I would much rather use the 3v coreless DC motor if possible:L293D-Motor-Driver is a typical Motor driver or Motor Driver IC which allows DC motor to drive on either direction. L293D is a 16-pin IC which can control a set of two DC motors simultaneously in any direction. It means that I can control two DC motor with a single L293D IC.Do you have ideas of this such a small motor-controllers exist or do I need to looking for a different solution? All I'm trying to do is have some kind of tiny component that will let me control both (or at least one) of the motors in both directions.Normally I could use L293D, but it requires 5V inputs for the trigger pins as well, but my project will be using only 3.7v.Thank you!
androidrobo
androidrobo's picture
Thank u for a ur great idea.
NealXu
NealXu's picture
Hi...as per my knowledge you really should get an amp meter and check the motors under load, or research rhe drills to find out what they draw. A good thing to remember is that a controller that is too big will not be an issue. One that is too small will cause problems.
