JAVA-PROGRAMMER WANTED!!!
11 posts / 0 new
Robotcruiser
Robotcruiser's picture
Hello,
 who can program a routine for RSM, that turns off the start-sequence and the powering down-mode after 10 minutes?
I´m searching for a programmer, who can do that for me.
Cannot be done in Java. The Java interpreter starts after the start up sequence, and the powering down is not controlled from the Java interpreter.
Robotcruiser
How can it be changed??? Is there a possibility to deactivate the powering down-option? because i let the robots dance in the club and it´s very nervly, that i have to press a key all 10 minutes!
Dance in the club?
No the timeout cannot be changed, but there is probably a way to prevent it happening other than pressing a key every few minutes.
Robotcruiser
What other way is there?
Well, Theoretically, if you can identify a signal that can be sent from one cpu to the the other that prevents it going into sleep mode, you can then create a program (Not java) or shell script, that runs in the background and transmits the signal periodically.
Dancing at the club?
Robotcruiser
Do you mean the cpu of the robots? Can you program such a routine for me?
 I´m a DJ and i have 2 RSMs with me, when i´m performing in the club. They should be dancing to my music.
The RSM has two cpu's, one controls the body, the other controls the LCD, speakers etc. The one that controls the body is the one that goes to sleep. So what you want is for the second CPU to send a wake up signal.
Assuming I have time, I might be able to create something to do the job.
Robotcruiser
This would be great. How much do you want for the job? Can i upload the routine to RSMs SD-Card, then?
Robotcruiser
Hello? Will you do the job???
As I said, if I find time
