Video of my faulty RS Media
22 posts / 0 new
machman
machman's picture
http://homepage.ntlworld.com/m.owen2/...
Can anyone help diagnose the problem from this video?
It is fitted with brand new batteries. It does the same with them removed and using PSU.
In a nutshell. No sound, No games, limited display but full functions otherwise.
Any help please.
Do you have an SD card and reader?
machman
machman's picture
Yes I do.
Robotdude101
Robotdude101's picture
Seems to me that the Volume is at mute. Try to turn it up.
machman
machman's picture
It is not volume muted, but thanks for your comment.
 Same problem as this thread
http://www.robocommunity.com/forum/thread/11948/Robosapien-Media-is-not-working-properly/
Quite a few of us getting this issue now.
Save this file into a directory on your SD card called rsupdate, stick it in your RS Media, turn it on, wait a few minutes, turn it off, and send me the two text files (dmesg.txt and ls.txt) from the root directory of your SD card.
machman
machman's picture
This is contents of  dmesg.txt
Linux version 2.4.18-rmk5-mx1ads-p3 (root@michael) (gcc version 2.95.3 20010315 (release)) #507 Fri Aug 25 20:10:50 HKT 2006
Processor: ARM/CIRRUS Arm920Tsid(wb) revision 0
Architecture: Motorola MX1ADS
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=fe01 ro mem=16M
Relocating machine vectors to 0xffff0000
Console: colour dummy device 80x30
Calibrating delay loop... 98.50 BogoMIPS
Memory: 16MB = 16MB total
Memory: 15000KB available (741K code, 297K data, 48K init)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
ttySA0 at I/O 0x206000 (irq = 29) is a MX1ADS
ttySA1 at I/O 0x207000 (irq = 23) is a MX1ADS
pty: 256 Unix98 ptys configured
DMA Initializing
block: 64 slots per queue, batch=16
SSFDC core support installed
MX1ADS nand I/O driver installed
SSFDC Partitions
nand0 : block 0x0000-0x003e : "Kernel" 1008 KB direct map
nand1 : block 0x003f-0x01fe : "RootDisk" 7168 KB random map
nand2 : block 0x01ff-0x047e : "DefaultDisk" 10240 KB random map
nand3 : block 0x047f-0x0f5a : "UserDisk" 44480 KB random map
nand4 : block 0x0f5b-0x0f7a : "WritableDisk" 512 KB random map
nand5 : block 0x0f7b-0x0f9a : "PassDisk" 512 KB random map
MX1ADS nand flash partition definitions installed
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 48K
mx1ads_startup
HD66770 Recycle LCD drivers 132x176 Version 0.1 installed
MXL-ADS Video Capture Module initialized
Call ssfdc_udisk_register_partition
Call usb_disk_register
USB Device mass storage interface installed
Date : 2005/01/06
Register usb_mmc_disk complete
MMC disk driver initialized
MX1ADS USB Device controller glue driver installed
EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
EXT2-fs error (device ssfdc(254,4)): ext2_check_page: bad entry in directory #2: unaligned directory entry - offset=0, inode=4294967295, rec_len=65535, name_len=255
Chip ID: 1b, Chip Revision: 0
MX1ADS : AC97 driver initialized.
Contents of  ls.txt
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 /config -> /buffer/config
lrwxrwxrwx    1 502      246            16 Jan  1 00:00 /meri_jam -> /buffer/meri_jam
lrwxrwxrwx    1 502      246            11 Jan  1 00:00 /tmp -> /buffer/tmp
lrwxrwxrwx    1 502      246            11 Jan  1 00:00 /var -> /buffer/var
/lnk:
/pw:
drwxr-xr-x    3 root     root         1024 Jan  1 00:00 .
drwxr-xr-x    2 root     root        12288 Jan  1 00:00 lost+found
-rwxr-xr-x    1 root     root           16 Jan  1 00:00 wowwee_emjava_id
drwxr-xr-x    1 502      246           408 Jan  1 00:00 ..
/buffer:
drwxr-xr-x    1 root     root            0 Jan  1 00:00 config
drwxr-xr-x    1 root     root            0 Jan  1 00:00 meri_jam
drwxr-xr-x    1 root     root            0 Jan  1 00:00 tmp
drwxr-xr-x    1 root     root            0 Jan  1 00:00 var
drwxr-xr-x    1 root     root            0 Jan  1 00:00 .
/bin:
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 dmesg -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 mkdir -> busybox
-rwxr-xr-x    1 502      246         87952 Jan  1 00:00 ash
-r-xr-xr-x    1 502      246        311460 Jan  1 00:00 busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 cat -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 chgrp -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 chmod -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 chown -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 cmp -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 cp -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 date -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 dd -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 df -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 du -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 echo -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 false -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 grep -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 gunzip -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 gzip -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 head -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 hostname -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 kill -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 ln -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 ls -> busybox
-rwxr-xr-x    1 502      246         25352 Jan  1 00:00 mkdosfs
-rwxr-xr-x    1 502      246         62176 Jan  1 00:00 mke2fs
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 mknod -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 more -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 mount -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 mv -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 pidof -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 ping -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 ps -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 pwd -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 rm -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 rmdir -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 sed -> busybox
lrwxrwxrwx    1 502      246             3 Jan  1 00:00 sh -> ash
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 sleep -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 sort -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 stty -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 sync -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 tar -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 tee -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 touch -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 true -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 umount -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 uname -> busybox
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 uniq -> busybox
-rwxr-xr-x    1 502      246          3264 Jan  1 00:00 uptime
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 vi -> busybox
-rwxr-xr-x    1 502      246          9044 Jan  1 00:00 vmstat
lrwxrwxrwx    1 502      246             7 Jan  1 00:00 zcat -> busybox
-rwxr-xr-x    1 502      246         33424 Jan  1 00:00 zmrx
-rwxr-xr-x    1 502      246         34608 Jan  1 00:00 zmtx
/default:
/dev:
brw-r--r--    1 502      246       86,   0 Jan  1 00:00 mmc
crw-------    1 502      246        8,   0 Jan  1 00:00 .devfsd
crw-r--r--    1 502      246       81,   0 Jan  1 00:00 audio
crw-------    1 502      246        5,   1 Jan  1 00:00 console
crw-------    1 502      246      205,  64 Jan  1 00:00 cuamx0
crw-r--r--    1 502      246       81,   0 Jan  1 00:00 dai
lrwxrwxrwx    1 502      246             8 Jan  1 00:00 dsp -> /dev/dai
crw-r--r--    1 502      246       88,   0 Jan  1 00:00 fb0
crw-r--r--    1 502      246        1,   7 Jan  1 00:00 full
drwxr-xr-x    1 502      246            16 Jan  1 00:00 i2c
crw-r-----    1 502      246        1,   2 Jan  1 00:00 kmem
crw-r--r--    1 502      246       81,   3 Jan  1 00:00 linein
drwxr-xr-x    1 502      246           128 Jan  1 00:00 loop
crw-r-----    1 502      246        1,   1 Jan  1 00:00 mem
crw-r--r--    1 502      246       81,   1 Jan  1 00:00 mic
crw-r--r--    1 502      246       81,   2 Jan  1 00:00 mixer
crw-r--r--    1 502      246       89,   0 Jan  1 00:00 mmcsd_switch
drwxr-xr-x    1 502      246           128 Jan  1 00:00 mtd
brwxr-xr-x    1 502      246       31,   0 Jan  1 00:00 mtd0
brwxr-xr-x    1 502      246       31,   1 Jan  1 00:00 mtd1
brwxr-xr-x    1 502      246       31,   2 Jan  1 00:00 mtd2
brwxr-xr-x    1 502      246       31,   3 Jan  1 00:00 mtd3
brwxr-xr-x    1 502      246       31,   4 Jan  1 00:00 mtd4
brwxr-xr-x    1 502      246       31,   5 Jan  1 00:00 mtd5
brwxr-xr-x    1 502      246       31,   6 Jan  1 00:00 mtd6
brwxr-xr-x    1 502      246       31,   7 Jan  1 00:00 mtd7
drwxr-xr-x    1 502      246            64 Jan  1 00:00 mtdblock
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock0 -> mtd0
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock1 -> mtd1
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock2 -> mtd2
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock3 -> mtd3
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock4 -> mtd4
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock5 -> mtd5
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock6 -> mtd6
lrwxrwxrwx    1 502      246             4 Jan  1 00:00 mtdblock7 -> mtd7
brw-r--r--    1 502      246      254,   0 Jan  1 00:00 nand0
brw-r--r--    1 502      246      254,   1 Jan  1 00:00 nand1
brw-r--r--    1 502      246      254,   2 Jan  1 00:00 nand2
brw-r--r--    1 502      246      254,   3 Jan  1 00:00 nand3
brw-r--r--    1 502      246      254,   4 Jan  1 00:00 nand4
brw-r--r--    1 502      246      254,   5 Jan  1 00:00 nand5
crw-r--r--    1 502      246       82,   0 Jan  1 00:00 nand_switch
crw-r--r--    1 502      246        1,   3 Jan  1 00:00 null
crw-r-----    1 502      246        1,   4 Jan  1 00:00 port
crw-r--r--    1 502      246        5,   2 Jan  1 00:00 ptmx
drwxr-xr-x    1 502      246             0 Jan  1 00:00 pts
drwxr-xr-x    1 502      246          4096 Jan  1 00:00 pty
crw-r--r--    1 502      246        1,   8 Jan  1 00:00 random
lrwxrwxrwx    1 502      246            10 Jan  1 00:00 root -> mtdblock/2
drwxr-xr-x    1 502      246             0 Jan  1 00:00 shm
drwxr-xr-x    1 502      246           156 Jan  1 00:00 sound
crw-r--r--    1 502      246      254,   0 Jan  1 00:00 ts
crw-r--r--    1 502      246        5,   0 Jan  1 00:00 tty
crw-r--r--    1 502      246        4,   0 Jan  1 00:00 tty0
crw-------    1 502      246        4,  64 Jan  1 00:00 ttyMX0
crw-r--r--    1 502      246        4,  65 Jan  1 00:00 ttyS1
crw-r--r--    1 502      246        1,   9 Jan  1 00:00 urandom
crw-r--r--    1 502      246       83,   0 Jan  1 00:00 usb_switch
drwxr-xr-x    1 502      246          1024 Jan  1 00:00 vc
drwxr-xr-x    1 502      246            32 Jan  1 00:00 vcc
crw-r--r--    1 502      246       84,   0 Jan  1 00:00 video
crw-r--r--    1 502      246       84,   1 Jan  1 00:00 video1
crw-r--r--    1 502      246       84,   2 Jan  1 00:00 video2
crw-r--r--    1 502      246       84,   3 Jan  1 00:00 video3
crw-r--r--    1 502      246       84,   4 Jan  1 00:00 video4
crw-r--r--    1 502      246        1,   5 Jan  1 00:00 zero
/etc:
-rw-------    1 502      246         12288 Jan  1 00:00 .profile.swp
-rwxr-xr-x    1 502      246         17315 Jan  1 00:00 RGB.txt
drwxr-xr-x    1 502      246            24 Jan  1 00:00 emtk
-rwxr-xr-x    1 502      246           216 Jan  1 00:00 fstab
-rwxr-xr-x    1 502      246           462 Jan  1 00:00 group
-rwxr-xr-x    1 502      246            61 Jan  1 00:00 hosts
-rwxr-xr-x    1 502      246           559 Jan  1 00:00 inittab
-rwxr-xr-x    1 502      246            78 Jan  1 00:00 issue
-rwxr-xr-x    1 502      246          2799 Jan  1 00:00 ld.so.cache
-rwxr-xr-x    1 502      246            66 Jan  1 00:00 ld.so.conf
-rwxr-xr-x    1 502      246           616 Jan  1 00:00 nsswitch.conf
-rwxr-xr-x    1 502      246          1251 Jan  1 00:00 passwd
-rwxr-xr-x    1 502      246          3914 Jan  1 00:00 profile
-rwxr-xr-x    1 502      246           468 Jan  1 00:00 protocols
drwxr-xr-x    1 502      246            20 Jan  1 00:00 rc.d
-rwxr-xr-x    1 502      246            79 Jan  1 00:00 securetty
drwxr-xr-x    1 502      246            24 Jan  1 00:00 ssh
drwxr-xr-x    1 502      246            20 Jan  1 00:00 sysconfig
drwxr-xr-x    1 502      246            32 Jan  1 00:00 terminfo
lrwxrwxrwx    1 502      246            10 Jan  1 00:00 version -> /etc/issue
/home:
drwxr-xr-x    1 502      246             0 Jan  1 00:00 guest
/icons:
-rw-r--r--    1 502      246         17807 Jan  1 00:00 bigbusy.gif
-rw-r--r--    1 502      246           480 Jan  1 00:00 folder.png
-rwxr-xr-x    1 502      246           587 Jan  1 00:00 folder.xpm
-rwxr-xr-x    1 502      246          1468 Jan  1 00:00 folder_blue_open.gif
-rw-r--r--    1 502      246           704 Jan  1 00:00 games_icon.png
drwxr-xr-x    1 502      246           320 Jan  1 00:00 main
drwxr-xr-x    1 502      246           200 Jan  1 00:00 menu
-rwxr-xr-x    1 502      246           274 Jan  1 00:00 mp3.xpm
-rw-r--r--    1 502      246           159 Jan  1 00:00 paused.png
-rwxr-xr-x    1 502      246            77 Jan  1 00:00 photo.gif
-rwxr-xr-x    1 502      246           481 Jan  1 00:00 photo.jpg
-rwxr-xr-x    1 502      246           585 Jan  1 00:00 photo.xpm
-rw-r--r--    1 502      246           180 Jan  1 00:00 recording.png
-rw-r--r--    1 502      246          6156 Jan  1 00:00 splash_ctrl.gif
-rw-r--r--    1 502      246          5978 Jan  1 00:00 splash_mani.gif
-rw-r--r--    1 502      246          5710 Jan  1 00:00 splash_prgm.gif
-rw-r--r--    1 502      246          6903 Jan  1 00:00 splash_sound.gif
-rw-r--r--    1 502      246          6521 Jan  1 00:00 splash_vision.gif
-rwxr-xr-x    1 502      246           462 Jan  1 00:00 video.jpg
/j2me:
drwxr-xr-x    1 502      246             0 Jan  1 00:00 jars
/lib:
-rwxr-xr-x    1 502      246        945236 Jan  1 00:00 ld-2.3.2.so
lrwxrwxrwx    1 502      246            11 Jan  1 00:00 ld-linux.so.2 -> ld-2.3.2.so
-rwxr-xr-x    1 502      246          4196 Jan  1 00:00 libBrokenLocale-2.3.2.so
lrwxrwxrwx    1 502      246            24 Jan  1 00:00 libBrokenLocale.so.1 -> libBrokenLocale-2.3.2.so
-rwxr-xr-x    1 502      246         10792 Jan  1 00:00 libSegFault.so
-rwxr-xr-x    1 502      246         10868 Jan  1 00:00 libanl-2.3.2.so
lrwxrwxrwx    1 502      246            15 Jan  1 00:00 libanl.so.1 -> libanl-2.3.2.so
-rwxr-xr-x    1 502      246       1277020 Jan  1 00:00 libc-2.3.2.so
lrwxrwxrwx    1 502      246            13 Jan  1 00:00 libc.so.6 -> libc-2.3.2.so
lrwxrwxrwx    1 502      246            17 Jan  1 00:00 libcfont.so.0 -> libcfont.so.0.0.0
-rwxr-xr-x    1 502      246         12408 Jan  1 00:00 libcfont.so.0.0.0
lrwxrwxrwx    1 502      246            17 Jan  1 00:00 libcom_err.so.2 -> libcom_err.so.2.0
-rwxr-xr-x    1 502      246          6196 Jan  1 00:00 libcom_err.so.2.0
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libconsole.so.0 -> libconsole.so.0.0.0
-rwxr-xr-x    1 502      246         62456 Jan  1 00:00 libconsole.so.0.0.0
-rwxr-xr-x    1 502      246         20136 Jan  1 00:00 libcrypt-2.3.2.so
lrwxrwxrwx    1 502      246            17 Jan  1 00:00 libcrypt.so.1 -> libcrypt-2.3.2.so
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libctutils.so.0 -> libctutils.so.0.0.0
-rwxr-xr-x    1 502      246         19300 Jan  1 00:00 libctutils.so.0.0.0
-rwxr-xr-x    1 502      246        872784 Jan  1 00:00 libdb-3.2.so
lrwxrwxrwx    1 502      246            12 Jan  1 00:00 libdb-3.so -> libdb-3.2.so
lrwxrwxrwx    1 502      246            12 Jan  1 00:00 libdb.so -> libdb-3.2.so
-rwxr-xr-x    1 502      246          9660 Jan  1 00:00 libdl-2.3.2.so
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 libdl.so.2 -> libdl-2.3.2.so
lrwxrwxrwx    1 502      246            13 Jan  1 00:00 libe2p.so.2 -> libe2p.so.2.3
-rwxr-xr-x    1 502      246         16112 Jan  1 00:00 libe2p.so.2.3
lrwxrwxrwx    1 502      246            16 Jan  1 00:00 libext2fs.so.2 -> libext2fs.so.2.4
-rwxr-xr-x    1 502      246         90156 Jan  1 00:00 libext2fs.so.2.4
lrwxrwxrwx    1 502      246            13 Jan  1 00:00 libgcc_s.so -> libgcc_s.so.1
-rwxr-xr-x    1 502      246         37896 Jan  1 00:00 libgcc_s.so.1
-rwxr-xr-x    1 502      246        698044 Jan  1 00:00 libm-2.3.2.so
lrwxrwxrwx    1 502      246            13 Jan  1 00:00 libm.so.6 -> libm-2.3.2.so
-rwxr-xr-x    1 502      246         14412 Jan  1 00:00 libmemusage.so
lrwxrwxrwx    1 502      246            17 Jan  1 00:00 libncurses.so.5 -> libncurses.so.5.2
-rwxr-xr-x    1 502      246        258632 Jan  1 00:00 libncurses.so.5.2
-rwxr-xr-x    1 502      246         76648 Jan  1 00:00 libnsl-2.3.2.so
lrwxrwxrwx    1 502      246            15 Jan  1 00:00 libnsl.so.1 -> libnsl-2.3.2.so
-rwxr-xr-x    1 502      246         41960 Jan  1 00:00 libnss_compat-2.3.2.so
lrwxrwxrwx    1 502      246            22 Jan  1 00:00 libnss_compat.so.2 -> libnss_compat-2.3.2.so
-rwxr-xr-x    1 502      246         13788 Jan  1 00:00 libnss_dns-2.3.2.so
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libnss_dns.so.2 -> libnss_dns-2.3.2.so
-rwxr-xr-x    1 502      246         37416 Jan  1 00:00 libnss_files-2.3.2.so
lrwxrwxrwx    1 502      246            21 Jan  1 00:00 libnss_files.so.2 -> libnss_files-2.3.2.so
-rwxr-xr-x    1 502      246         15104 Jan  1 00:00 libnss_hesiod-2.3.2.so
lrwxrwxrwx    1 502      246            22 Jan  1 00:00 libnss_hesiod.so.2 -> libnss_hesiod-2.3.2.so
-rwxr-xr-x    1 502      246         36180 Jan  1 00:00 libnss_nis-2.3.2.so
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libnss_nis.so.2 -> libnss_nis-2.3.2.so
-rwxr-xr-x    1 502      246         42164 Jan  1 00:00 libnss_nisplus-2.3.2.so
lrwxrwxrwx    1 502      246            23 Jan  1 00:00 libnss_nisplus.so.2 -> libnss_nisplus-2.3.2.so
-rwxr-xr-x    1 502      246         12500 Jan  1 00:00 libnss_winbind.so
lrwxrwxrwx    1 502      246            17 Jan  1 00:00 libnss_winbind.so.2 -> libnss_winbind.so
-rwxr-xr-x    1 502      246        635868 Jan  1 00:00 libnss_wins.so
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 libnss_wins.so.2 -> libnss_wins.so
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 libpam.so.0 -> libpam.so.0.72
-rwxr-xr-x    1 502      246         34128 Jan  1 00:00 libpam.so.0.72
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libpam_misc.so.0 -> libpam_misc.so.0.72
-rwxr-xr-x    1 502      246          8424 Jan  1 00:00 libpam_misc.so.0.72
lrwxrwxrwx    1 502      246            15 Jan  1 00:00 libpamc.so.0 -> libpamc.so.0.72
-rwxr-xr-x    1 502      246         10320 Jan  1 00:00 libpamc.so.0.72
-rwxr-xr-x    1 502      246          5176 Jan  1 00:00 libpcprofile.so
lrwxrwxrwx    1 502      246            16 Jan  1 00:00 libproc.so -> libproc.so.3.2.1
-rwxr-xr-x    1 502      246         53840 Jan  1 00:00 libproc.so.3.2.1
-rwxr-xr-x    1 502      246         65480 Jan  1 00:00 libpthread-0.10.so
lrwxrwxrwx    1 502      246            18 Jan  1 00:00 libpthread.so.0 -> libpthread-0.10.so
-rwxr-xr-x    1 502      246         62468 Jan  1 00:00 libresolv-2.3.2.so
lrwxrwxrwx    1 502      246            18 Jan  1 00:00 libresolv.so.2 -> libresolv-2.3.2.so
-rwxr-xr-x    1 502      246         28980 Jan  1 00:00 librt-2.3.2.so
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 librt.so.1 -> librt-2.3.2.so
lrwxrwxrwx    1 502      246            12 Jan  1 00:00 libss.so.2 -> libss.so.2.0
-rwxr-xr-x    1 502      246         16868 Jan  1 00:00 libss.so.2.0
-rwxr-xr-x    1 502      246         21028 Jan  1 00:00 libthread_db-1.0.so
lrwxrwxrwx    1 502      246            19 Jan  1 00:00 libthread_db.so.1 -> libthread_db-1.0.so
-rwxr-xr-x    1 502      246          8520 Jan  1 00:00 libutil-2.3.2.so
lrwxrwxrwx    1 502      246            16 Jan  1 00:00 libutil.so.1 -> libutil-2.3.2.so
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 libuuid.so.1 -> libuuid.so.1.2
-rwxr-xr-x    1 502      246         12604 Jan  1 00:00 libuuid.so.1.2
lrwxrwxrwx    1 502      246            16 Jan  1 00:00 libwrap.so.0 -> libwrap.so.0.7.6
-rwxr-xr-x    1 502      246         28856 Jan  1 00:00 libwrap.so.0.7.6
drwxr-xr-x    1 502      246           228 Jan  1 00:00 modules
/meri_config:
-rw-r--r--    1 502      246           344 Jan  1 00:00 meri_emsoft.cfg
/mnt:
drwxr-xr-x    3 root     root         4096 Jan  1 00:00 sd
drwxr-xr-x    1 502      246           148 Jan  1 00:00 default
/proc:
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 1
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 2
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 3
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 4
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 5
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 56
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 6
dr-xr-xr-x    3 root     root            0 Jan  1 00:00 61
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 bus
-r--r--r--    1 root     root            0 Jan  1 00:00 cmdline
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 cpu
-r--r--r--    1 root     root            0 Jan  1 00:00 cpuinfo
-r--r--r--    1 root     root            0 Jan  1 00:00 devices
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 driver
-r--r--r--    1 root     root            0 Jan  1 00:00 execdomains
-r--r--r--    1 root     root            0 Jan  1 00:00 fb
-r--r--r--    1 root     root            0 Jan  1 00:00 filesystems
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 fs
-r--r--r--    1 root     root            0 Jan  1 00:00 interrupts
-r--r--r--    1 root     root            0 Jan  1 00:00 iomem
-r--r--r--    1 root     root            0 Jan  1 00:00 ioports
-r--------    1 root     root     16781312 Jan  1 00:00 kcore
-r--------    1 root     root            0 Jan  1 00:00 kmsg
-r--r--r--    1 root     root            0 Jan  1 00:00 ksyms
-r--r--r--    1 root     root            0 Jan  1 00:00 loadavg
-r--r--r--    1 root     root            0 Jan  1 00:00 locks
-r--r--r--    1 root     root            0 Jan  1 00:00 meminfo
-r--r--r--    1 root     root            0 Jan  1 00:00 misc
-r--r--r--    1 root     root            0 Jan  1 00:00 mmc
-r--r--r--    1 root     root            0 Jan  1 00:00 modules
-r--r--r--    1 root     root            0 Jan  1 00:00 mounts
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 net
-r--r--r--    1 root     root            0 Jan  1 00:00 partitions
lrwxrwxrwx    1 root     root           64 Jan  1 00:00 self -> 61
-rw-r--r--    1 root     root            0 Jan  1 00:00 slabinfo
-r--r--r--    1 root     root            0 Jan  1 00:00 ssfdc
-r--r--r--    1 root     root            0 Jan  1 00:00 stat
-r--r--r--    1 root     root            0 Jan  1 00:00 swaps
dr-xr-xr-x    2 root     root            0 Jan  1 00:00 sysvipc
dr-xr-xr-x    4 root     root            0 Jan  1 00:00 tty
-r--r--r--    1 root     root            0 Jan  1 00:00 uptime
-r--r--r--    1 root     root            0 Jan  1 00:00 usb_disk
-r--r--r--    1 root     root            0 Jan  1 00:00 version
dr-xr-xr-x   17 root     root            0 Jan  1 00:00 .
/programs:
-rw-------    1 502      246        868144 Jan  1 00:00 8mb.sf2
drwxr-xr-x    1 502      246           288 Jan  1 00:00 fonts
/root:
-rwxr-xr-x    1 502      246         31136 Jan  1 00:00 capture_pic_qqvga
/sbin:
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 halt -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 insmod -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 klogd -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 lsmod -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 makedevs -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 mkswap -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 modprobe -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 poweroff -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 reboot -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 rmmod -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 swapoff -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 swapon -> ../bin/busybox
lrwxrwxrwx    1 502      246            14 Jan  1 00:00 syslogd -> ../bin/busybox
/testscript:
-rw-------    1 502      246           180 Jan  1 00:00 test.sh
-rwxr-xr-x    1 502      246          3660 Jan  1 00:00 write_confile
/usr:
drwxr-xr-x    1 502      246           528 Jan  1 00:00 bin
drwxr-xr-x    1 502      246          1712 Jan  1 00:00 lib
drwxr-xr-x    1 502      246            40 Jan  1 00:00 local
drwxr-xr-x    1 502      246            96 Jan  1 00:00 sbin
drwxr-xr-x    1 502      246            20 Jan  1 00:00 share
Couldnt attach this to email through this forum.
I hope this helps you, and thanks for your time
Hmm.... Nothing particularly useful there. Have to try something else. Something bad is going on though, your missing some important files.
machman
machman's picture
Nocturnal, I am left with the impression that on booting up some of the files that would be part of the basic operating system have become corrupted or deleted, hence the partial features.
I can get my head around the fact that you can format the RS media drive, and without installing some kind of software it can reboot and run fine. I assume the os is on something like a eeprom, like a mobile phone and would require flashing or similar to reinstall the OS. But then seeing its a linux OS on the files suggests not? Undecided
Whether it helps you. When I ran the media with the sd card in place and the update file, the LCD displayed the wowwee flash screen all the time, and once it eventually started it did not respond to any media commands nor could you access any menu's. With the SD removed it was back to the same as in the video.
Not quite, the operating system is fine, WowWee's software is fine. What's missing is the links WowWee's software uses to find the various personality / interface files. WowWee's software is setup to look in one specific place for files, that place is essentially a whole lot of links to where the files actually reside. Not sure why WowWee did it like that, but there probably was a reason.
The RS Media has 5 partions on its Flash memory, when you format it, you are really only formatting one of the partitions.
When the SD card is inserted, and the right files exist, it stop the boot process part way through and executes the scripts from the SD card. The reason the WowWee log stayed on the screen and it did not respond to commands (though after a while it would have done the startup routine without sound) is because my script does not start WowWee's user interface software.
I've updated the script to include a few more tests. There should be an additional text file when you are done called mount.txt, and the ls.txt will be much bigger (i would recomened not posting it in the forum due to its size).
machman
machman's picture
Nocturnal here are links to the files. I dont have your email address.
 all the files
You have to admit that the files do look impressive when postingCool
Again thanks for your time.
Nocturnal, when you say 'formatting one of the partitions', do you mean by performing Restore as referenced in this WowWee tech support FAQ?
"- formatting RS Media
If you want to format your RS Media and return it to its original state (factory settings), you can use RS Media Editing Suite software to do so. In the RS Media Editing Suite software, go to Media Organizer and locate the Restore button. You will be prompted with a dialog box, following the on-screen instruction to format your RS Media.
After you reboot your RS Media, the factory settings should be restored (same as when you first booted him up) and all previously stored data will be erased."
Just a generic question, in the ls.txt, the "->" indicates a file link? (symbolic link, is it?)
Machman was saying he was having difficulty with the idea that you could format the RS Media and without installing anything, it would boot and function. I was explaining the how.
Yes -> indicates a symbolic link, those of you who don't use linux, think of it as similar to a shortcut under windows, only much better (you can actually treat links as files, unlike with shortcuts), and has been around forever.
You will notice that /lnk is empy, it should have a bunch of symbolic links.
Machman, I've created a script here that will attempt to fix the problem, copy it to the sd card and run it.
machman
machman's picture
WaaaaaaHooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Nocturnal YOU ARE THE MAN!!!!!!!Cool
Initial boot on the card made everything come back. Reboot without card seems to be the same. I am about to enjoy the Man Utd game so will complete a full test tomorrow. But its looks as though you have got it sussed. I new my money was safe.
Thanks from me and my now smiling 8 year old son and his 22 month old broLaughing
Oh, man, now I'm not sure I want an RSMedia.
I live and breathe Unix install quirks and foibles fifty hours a week. I'm not sure I want to reuse those skills on my "play" time.
I suppose it could be worse.
I could be based on Windows. blarrrrrgh.
heh, WfW 3.11! Network! yay!
Congrats machman and especially to the wiz Nocturnal! Do you think this may be a general solution?
Or perhaps each  dying RSM will have different  areas of files missing... I guess only time will tell.
I'm going to run the first listing script on my (healthy- knock wood) RSM to compare to Machman's (before the fixing), for my own curiosity.
I'm glad that fixed things for you machman.
Hey, WfW 3.11 was stable (or so my rusty memory suggests) it was 95 that introduced the BSOD wholesale.
machman
machman's picture
I can confirm that this was a full fix for the problem. Thanks again NocturnalWink
RobosapienV2-4mem8
RobosapienV2-4mem8's picture
What can one say, Nocturnal,He's the man.
UNCLE
UNCLE's picture
machman said: WaaaaaaHooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!! Nocturnal YOU ARE THE MAN!!!!!!!Cool Initial boot on the card made everything come back. Reboot without card seems to be the same. I am about to enjoy the Man Utd game so will complete a full test tomorrow. But its looks as though you have got it sussed. I new my money was safe.   Thanks from me and my now smiling 8 year old son and his 22 month old broLaughing
Please-help-me-out-by-posting-a-step-by-step-sd-card-recovery of my rs media.
I've got the same fault without sound and blank screen etc..
I've already tried to format and restore method which both didn't work at all.
I've also tried to try using the sd card to solve but maybe i don't understand what files to put in the sd card and what i'm suppose to do.
thanks
Nocturnal said:
Save this file into a directory on your SD card called rsupdate, stick it in your RS Media, turn it on, wait a few minutes, turn it off...
You may also find the description of how to run a script off the sd card in this thread helpful.
Musa
Musa's picture
Hi Please can some one help me I have the same problem. Can some one give me a step by step guide. I have an SD card also My computer is running Vista 64bit will this make a diffrence. The file i download is a text file is this correct. Please Help as I can not replace the RS media as it is now discontinued in the UK. I have access to a full working one if i need to get hold of it. Thansk
