Who can program RSM?
Robotcruiser
Robotcruiser's picture
I´m searching for someone, who can write a routine for RS Media, that send a signal in a special time-period from one cpu to the other, to stop the powerdown-mode, after 10 minutes.
 Who can do the job? Money mouth Money waits...
roschler
roschler's picture
RobotCruiser,
There's another way to do this if you have a PC at your club.  Buy a USB UIRT and a piece of software called Girder.  Record the RS Media stop command from the remote control.  Then program Girder to send the STOP command every 10 minutes, which should keep the robots from powering down.
You can get the USB UIRT at UsbUirt.com and Girder from Promixis.com.
I have to warn you in advance that I can't guarantee this will work so you will have to get those items at your own risk with the risk being it might not do what you want (of course but just making sure you know).   Also, I can't tell you exactly how to do this in Girder because I just use Girder to record the robot commands; but I'm pretty sure Girder has this capability because it's sole purpose is to automate PC commands and it already has a driver for the USB UIRT.
Robert
Robotcruiser
Thanks Robert, i will try it out!
