Contributions Problem
I noticed when looking at Peter Redmer's profile, it shows 7 Comments in 4 Discussion Threads. Actually clicking through, I get 2 comments in 1 discussion thread. I assume this is another private postings issue.
Peter is an adminstrator, and he does contribute to the restricted access moderation group threads, so that's likely part of the discrepancy you are seeing in the numbers. It does not account for all of the delta, but I'm assuming there other groups he is in that I don't see.
Jeff Block
Jeff Block's picture
I think you're both probably right at least in part, but I suspect there is also a bug at work here.  Seems like users (whatever their permissions) should see what they expect to see.  I'll check in with our technical team to get a precise read on this.
Thanks for pointing this out, Nocturnal.
I'm not quite sure I follow you Jeff.
most other things in profiles have been adjusted, and appear to everyone as they would appear to a normal user (regardless of the permissions of the viewer).
