The Elvinator Source Code and Video along with other helpfull code and Video
104 posts / 0 new
RobosapienV2-4mem8
RobosapienV2-4mem8's picture
Hey GW, I see now how this section of code opporates the A-B + A-B of the two H bridges.
LegLeftBack        PIN           8     'sets left legs backwards to pin 8
LegLeftFront       PIN           9     'sets left legs foward to pin 9
LegRightBack       PIN           10    'sets right legs backwards to pin 10
LegRightFront      PIN           11    'sets right legs foward to pin 11
One controller for:
And one for:
Sending a 0 or 1 to any of the A-B controllers make it go fwd,back,cw,cc,spin ect.
I knew this of course for a two wheel system but wasn't sure if you could use  spider configuiration [two H bridges] code for a two wheel system, But really it's the same setup. Just different mechanics.
You nailed it right on the head 4mem8, Congrats your learning something and this is what this thread is for. The spider that I have is driven by two motors in a gearbox, thats why I chose this one. If you look further down the code in the GoFoward: subroutine you'll see that I have a pause in this along with a FOR NEXT command this will slow down the motors and by changing the value of the PAUSE to a higher number will slow down the Motor speed and decreasing the value will speed it up or get rid of it along with the FOR NEXT commands and leave the pins HIGH will run the motors on fast until you shut them down back to LOW. I have changed my program and once I post it please compair the diffrence regarding the leg movements. This will help you better understand the functions of making your motors move under a Hbridge configuration. There are diffrent ways to do this as well but I'm making it easy to understand. Then you can make changes to it to make the program run faster and less programming lines. I'll show you the diffrence in later post.
RobosapienV2-4mem8
Thanks for the confidence GW I'm really enjoying it, I just have to find more time to swat up. Had a busy week at work so not much robotics done this week. See if I can get a few hrs over the weekend.
no problem 4mem8, I had a hard week too. and know I'm taking my bike a Honda VTX1300R 2006and wife to bike-week in Daytona, FL for the day so no robotics for me on Saturday aka Sunday for you.. lol
RobosapienV2-4mem8
Cool GW, Have a nice day.
New changes to the random Tilt/Pan code. You can now step the speed of the tilt and pan by changing the STEP commands number. 1 being the slowest and all other higher is faster. Also look at the diffrent Variables added and the "i VAR" changed to a Word rather than a Byte. Hope this helps you out 4mem8. Here is the NEW code:
' {$STAMP BS2}
' {$PBASIC 2.5}
' random movements for tilt and pan movements
' Change the STEP command number higher to speed the scan up
' variables
Tilt                      PIN            1   ' set tilt to pin 1
Pan                     PIN            0   ' set pan to pin 0
tiltseed               VAR           Word  ' set var seed for tilt
panseed             VAR           Word  ' set var seed for pan
TPseed                VAR           Word  ' set to check for tilt or pan
tpselect               VAR     tpseed.BIT0 ' Bit0 of the random number
tiltdelay               VAR           Word  'tiltdelay
pandelay             VAR           Word  'pandelay
i                           VAR           Word  'counter
tilttime                 VAR           Byte  'tilttime
pantime               VAR           Byte  'pantime
LastDelayTilt        VAR           Word ' used to ramp down speed for tilt
LastDelayPan       VAR           Word 'used to ramp down speed for pan
' initialization/maxline
  LOW tilt
  LOW pan
  LastDelayTilt = 550            'set for center of tilt
  LastDelayPan = 650             'set for center of pan
  tiltdelay = 400
  pandelay = 1000
  TiltSeed = 400
  PanSeed = 1000
  TPseed = 1
  TiltTime = 10
  PanTime = 30
  FOR i = 0 TO TiltTime    'center tilt/pan unit
    PULSOUT tilt, LastDelayTilt
    PAUSE 18
  NEXT
  FOR i = 0 TO PanTime
    PULSOUT pan, LastDelayPan
    PAUSE 18
  NEXT
 main:
  RANDOM tpseed
  IF tpselect = 0 THEN GOSUB panit 'for tilt or pan direction
  RANDOM TiltSeed ' give a random number
  tiltdelay = tiltseed
  DO WHILE (tiltdelay > 750 OR tiltdelay < 550 ) 'check to see if tilt is within specs
  RANDOM TiltSeed  ' mixup numbers
  LOOP 'continue till values are right for movement
  GOSUB tiltit
  GOTO main ' start all over
tiltIt:
   FOR i = LastDelayTilt TO TiltDelay STEP 1 'Change Step Number Higher to go faster
      PULSOUT tilt, i 'send out pulse to servo
      PAUSE 30
   NEXT
    LastDelayTilt = TiltDelay
RETURN
PanIt:
RANDOM panseed ' mix random number with seed value
  pandelay=panseed
  DO WHILE (pandelay > 1000 OR pandelay < 200 ) ' wait till within movement specs
    RANDOM panseed ' mix numbers up again
    pandelay=panseed
  LOOP ' loop until numbers are within correct movement range
  FOR i = Lastdelaypan TO pandelay STEP 1 'Change Step Number Higher to go faster
    PULSOUT pan, i
    PAUSE 30
  NEXT
    LastDelayPan = PanDelay
RETURN
Anyone have an opinion if the Radio Shack Basic Stamp kit is worth it at $79? It includes one servo as well.
It's limited because you can not pull the BS2 Stamp off the board, It is incorporated into it, But it is a good base to start with learning Pbasic. As long as you don't mind having the full board in your projects , I say it's a good investment. The servo I think s a continus rotation servo, great for wheel bots so you don't have to mod it. It is well worth the price.
RobosapienV2-4mem8
Pretty good price to me milw, I'd go for it.
GWjax: Thanks for the code I will check it out tonight, and will compare to the other and see what you have done.
Nocturnal: I will post another pic tonight of the rivet detal and paint, Not to brilliant at present until I scratch and rub the right area's to get the weathered effect.
Peter Redmer's picture
Hey everybody - part 4 of the "Elvinator" hack is now posted!!!!
Head on over and check it out!
Thanks to GWJax for all his hard work on this awesome project!!
Pete
Testing your Ping sensor. Use this program to test for both Inch and cm distance. When you find the right distance you want write down the number of the Time it took to get the Ping back to the RX and use this number to calculate your desired distance for your bot.
' Measure distance with Ping))) sensor and display in both in & cm
' you'll find out that you should get 134 in max and 364 cm max
' use this program to get the maximum distance required you need and write down the numbers
' {$STAMP BS2}
' {$PBASIC 2.5}
' Conversion constants for room temperature measurements.
CmConstant CON 2260
InConstant CON 890
cmDistance VAR Word
inDistance VAR Word
Time VAR Word
DO
PULSOUT 15, 5  ' ping 5 times on pin 15
PULSIN 15, 1, time ' get one ping back on pin 15
cmDistance = cmConstant ** time ' convert in cm
inDistance = inConstant ** time ' convert in inch
DEBUG HOME, DEC3 cmDistance, " cm"
DEBUG CR, DEC3 inDistance, " in", cr
DEBUG DEC Time, " = Time it took to get Ping back"
PAUSE 100
LOOP
RobosapienV2-4mem8
Great GW, Thanks.
4mem8 I need you to run this program and give me the data that comes out on the debug screen before I do any movement routines, Please put Wall-E in a place on the floor where there is a lot of distance all around him. I need to get the Max data for the movement routines. Also check and see if your LED are on when you run the program. I've made a lot of changes so look it over. Thanks GWJax
Here is the Code:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Wall-E move routine for tilt/pan, eye detection and body movement
' for robosienianv2-4mem8 @ WWW.RoboCommunity.com
' By: GWJax 3/28/2008
' Set Wall-E's Varaibles
inDistance             VAR           Byte 'holds data for inch for distance 0-255
Time                   VAR           Word 'holds data for time it takes to get a ping reply
i                      VAR           Byte  'counter
CenterFront            VAR           Byte  'Holds center head front distance
RightCenter            VAR           Byte  'Holds right center distance
LeftCenter             VAR           Byte  'holds left center distance
DownCenter             VAR           Byte  'holds down head center distance
UpCenter               VAR           Byte  'holds up center head distance
LeftDownMax            VAR           Byte  'holds head left down max distance
RightDownMax           VAR           Byte  'holds head right down max distance
CenterUpMax            VAR           Byte  'Holds head center up max distance
RightUpMax             VAR           Byte  'Holds head right up max distance
LeftUpMax              VAR           Byte  'holds head left up max distance
' Set constants
InConstant CON 890 'set for inch in room temp 70 deg F
' Set Wall-E pin lay out
Tilt  PIN 0 'sets tilt to pin 1
Pan   PIN 1 'sets pan to pin 0
Eyes  PIN 7 'sets Ping eyes to pin 7
Wall_E_LfBack  PIN 8 'sets left legs backwards to pin 8
Wall_E_LfFront PIN 9 'sets left legs foward to pin 9
Wall_E_RtBack  PIN 10 'sets right legs backwards to pin 10
Wall_E_RtFront PIN 11 'sets right legs foward to pin 11
' setup pin I/O's
HIGH Wall_E_lfBack
HIGH Wall_E_LfFront
HIGH Wall_E_RtBack
HIGH Wall_E_RtFront
LOW Tilt
LOW Pan
'set Wall-E's head looking front and center
GOSUB PanItCenter
'main routine
Main:
GOSUB LookAround
STOP 'stop program to read results to continue programming
IF CenterFront > 11 THEN 'is object greater than 11" from eyes center
  GOTO Wall_E_Foward
  ELSEIF CenterFront <= 11 THEN 'is object = to or less than 11" from eyes center
    'GOTO LookAround ' look for the best route to take
  ENDIF
GOTO Main ' do it all over again
'Wall-E stop moving
Wall_E_STOP:
HIGH Wall_E_lfBack
HIGH Wall_E_LfFront
HIGH Wall_E_RtBack
HIGH Wall_E_RtFront
GOTO Main
'Pan Wall-E's head Center and Fast
PanItCenter:
FOR i = 0 TO 10
  PULSOUT Tilt, 650  'sends out pulse to tilt servo and center Change 650 to your setting
  PAUSE 18           'wait for 18ms to complete turning
NEXT
FOR i = 0 TO 30      'Start pan movement to center
  PULSOUT Pan,650    'sends out pulse to pan servo and center Change 650 to your setting
NEXT
RETURN
'eyes ping
CkEyes:
PULSOUT Eyes, 5  ' ping 5 times
PULSIN Eyes, 1, time ' get one ping back
InDistance = InConstant ** time ' convert in inch
RETURN
LookAround:
GOSUB PanItCenter                'Center head
  GOSUB CkEyes               'look at the distance in the center
    CenterFront = InDistance     'set CenterHead with distance recorded
    DEBUG CLS, "CenterFront=",DEC3 CenterFront, cr
GOSUB LookDownCenter
  GOSUB CkEyes
    DownCenter = InDistance
    DEBUG "LookDownCenter=",DEC3 DownCenter, CR
GOSUB LookUpMax
  GOSUB CkEyes
    UpCenter = InDistance
    DEBUG "LookUpMax =",DEC3 UpCenter, cr
GOSUB PanItRightCenter
  GOSUB CkEyes
    RightCenter = InDistance
    DEBUG "RightCenter =",DEC3 RightCenter, CR
GOSUB LookUpMax
  GOSUB CkEyes
    RightUpMax = InDistance
    DEBUG "RightUpMax =",DEC3 RightUpMax,cr
GOSUB LookDownLR
  GOSUB CkEyes
    RightDownMax = InDistance
    DEBUG "RightDownMax =",DEC3 RightDownMax,cr
GOSUB PanItLeftCenter
  GOSUB CkEyes
    LeftCenter = InDistance
    DEBUG "LeftCenter =",DEC3 RightCenter,cr
GOSUB LookUpMax
  GOSUB CkEyes
    LeftUpMax = InDistance
    DEBUG "LeftUpMax =",DEC3 LeftUpMax,cr
GOSUB LOOKDOWNLR
  GOSUB CkEyes
    LeftDownMax = InDistance
    DEBUG "LeftDownMax =",DEC3 leftDownMax,cr
GOSUB PanItCenter
RETURN
'Head Routines
LookDownLR:
  FOR i = 0 TO 10
    PULSOUT Tilt, 650
    PAUSE 18
  NEXT
RETURN
LookUpMax:
FOR i = 0 TO 10
  PULSOUT Tilt, 300
  PAUSE 18
NEXT
RETURN
LookDownCenter:
GOSUB PanItCenter
  FOR i = 0 TO 10
    PULSOUT Tilt,650
    PAUSE 18
  NEXT
RETURN
PanItRightMax:                   'pans head right to max
FOR i = 0 TO 30
  PULSOUT Pan, 200
  PAUSE 18
NEXT
RETURN
PanItRightCenter:                'pans head max to right with center tilt
FOR i = 0 TO 10
  PULSOUT Tilt, 550
  PAUSE 18
NEXT
FOR i = 0 TO 30
  PULSOUT Pan, 200
  PAUSE 18
NEXT
RETURN
PanItLeftCenter:                 'pans head max to left with center tilt
FOR i = 0 TO 10
  PULSOUT Tilt, 550
  PAUSE 18
NEXT
FOR i = 0 TO 30
  PULSOUT Pan, 1000
  PAUSE 18
NEXT
RETURN
PanItLeftMax:                    'pans head max to left only
FOR i = 0 TO 30
  PULSOUT pan, 1000
  PAUSE 18
NEXT
RETURN
Wall_E_Foward:
GOSUB CkEyes
  LOW Wall_E_RtFront
  LOW Wall_E_LfFront
    DO WHILE InDistance < 11
      GOSUB CkEyes
    LOOP
GOTO Wall_E_Stop
GoFowardMedium:
                        'moves foward Medium rate
DO WHILE InDistance < 6
  GOSUB CkEyes
    LOW Wall_E_RtFront
    PAUSE 50
    HIGH Wall_E_RtFront
    LOW Wall_E_LfFront
    PAUSE 50
    HIGH Wall_E_LfFront
LOOP
GOTO Wall_E_Stop
GoFowardSlow:
GOSUB CkEyes
  DO WHILE InDistance > 4
   LOW Wall_E_RtFront
    PAUSE 50
  HIGH Wall_E_RtFront
  LOW Wall_E_LfFront
    PAUSE 50
  HIGH Wall_E_LfFront
  GOSUB CkEyes
 LOOP
GOTO Wall_E_Stop
GoBackFast:
GOSUB CkEyes
  LOW Wall_E_RtBack
  LOW Wall_E_LfBack
    DO WHILE InDistance < 17
    GOSUB CkEyes
    LOOP
GOTO Wall_E_Stop
GoBackMedium:           ' Moves back medium rate
GOSUB CkEyes
  DO WHILE indistance < 6
    LOW Wall_E_RtBack
     PAUSE 50
   HIGH Wall_E_RtBack
   LOW Wall_E_LfBack
    PAUSE 50
  HIGH Wall_E_LfBack
  LOOP
GOTO Wall_E_Stop
GoBackSlow:
GOSUB CkEyes
  DO WHILE InDistance < 4
    LOW Wall_E_RtBack
     PAUSE 100
   HIGH Wall_E_RtBack
   LOW Wall_E_LfBack
    PAUSE 100
  HIGH Wall_E_LfBack
  LOOP
GOTO Wall_E_Stop
RobosapienV2-4mem8
Thanks GW, It may be a while before I get to this as Wall-E is not complete yet and the Hbridge is still on the bread board. We have to decorate the lounge and rip up carpet, Worst of all dismantle my workstation, A huge job if you were to see my system. Which means I will have to upgrade my Electronics Pc for email ect. M'mmm.
Here is the H bridge Test routine you asked me to make for you. I hope It works as I can not test it here without building the H-Bridge you made. But I'm sure it will it has no syntax errors in it so it should do fine, It will go foward fast, stop, go back fast, a hard break and float break, clock wise, stop, counter clockwise, stop and loop to do again in 2 sec. Let me know If tis works!
' {$STAMP BS2}
' {$PBASIC 2.5}
' Motor movement for Wall-E H-Bridge Test routine
' By GWJax 28 Mar 2008
Wall_E_LfBack  PIN 8 'sets left track backwards to pin 8
Wall_E_LfFront PIN 9 'sets left track foward to pin 9
Wall_E_RtBack  PIN 10 'sets right track backwards to pin 10
Wall_E_RtFront PIN 11 'sets right track foward to pin 11
' setup pin I/O's
HIGH Wall_E_lfBack
HIGH Wall_E_LfFront
HIGH Wall_E_RtBack
HIGH Wall_E_RtFront
Main:
GOSUB Wall_E_STOP
GOSUB Wall_E_FowardFast
  PAUSE 1000 ' let run for one sec.
GOSUB Wall_E_STOP
GOSUB Wall_E_BackFast
GOSUB Wall_E_HBStop ' opps put on the breaks!
  PAUSE 250 ' pause 1/4 sec
GOSUB Wall_E_Stop ' reset lines for floating
GOSUB Wall_E_CW
  PAUSE 500 ' run for 1/2 sec
GOSUB Wall_E_Stop
GOSUB Wall_E_CCW
GOSUB Wall_E_Stop
PAUSE 2000 ' wait for 2 sec
GOTO Main ' return to the start and do again
'Wall-E stop moving
Wall_E_STOP:
HIGH Wall_E_lfBack
HIGH Wall_E_LfFront
HIGH Wall_E_RtBack
HIGH Wall_E_RtFront
RETURN
Wall_E_FowardFast:
  LOW Wall_E_RtFront
  LOW Wall_E_LfFront
RETURN
Wall_E_BackFast:
  LOW Wall_E_RtBack
  LOW Wall_E_LfBack
RETURN
'Wall-E move clock wise
Wall_E_CW:
  LOW Wall_E_RtBack
  LOW Wall_E_LfFront
RETURN
'Wall-E moving counter clock wise
Wall_E_CCW:
  LOW Wall_E_LfBack
  LOW Wall_E_RtFront
RETURN
'Wall-E hard break stop
Wall_E_HBStop:
  LOW Wall_E_lfBack
  LOW Wall_E_LfFront
  LOW Wall_E_RtBack
  LOW Wall_E_RtFront
RETURN
RobosapienV2-4mem8
Great Gw, Thanks for the code, Will test asp. I have been moving ALL my PC grear today, The whole dinning room table is choka full of gear + 4 banana box's of cables. I have just setup my laptop for communication to this site. I don't want to miss anything, Ha Ha.
I was hopping you would get it before you riped everything down. Let me know how it goes! Thanks GWJax
ps. not much happing here in robo world lol. I had just done some coding for a client of mine for a mail merge to over 1/2 million people. That was a lot of coding but it works great and I'll install it on sat for them on their computer. It only took 6 hrs to do it, not bad I think. Its a good thing I have a stash of routines that are plug and play that I made. by the way it was programed Visual Basic 6.0. I must have a think for basic programming, I tried C and C++ and Visual C++ but it just does not make sence to me for some reason. now Assembly I'm a bit rusty but catching up on it for the Elivnator.
RobosapienV2-4mem8
Assembly!! I thought that you were coding in P-basic for Elvinator!! Don't worry about me dissmantling my PC GW, I still have my Electronics room PC for the coding so I will download it tomorrow and let you know. I was only going to use my lapyop for Robot stuff but I have now decided to also use it for this site to keep in touch whilst our living room is upgraded. I will load M/S picture it to upload my photo's.
Yep Assembly! for some of the movements for the Pics I plan on installing, The pics will intertwine with the Basic Stamps and the will run faster while the Basic Stamps can do other monitoring sensors and the such.. Sorry I thought I told you this. But if I did not SUPPRISE!!! I told you I would through in a few hard coding... I glade you have the laptop as that is what I use instead of my PC so I can bring all my stuff in the car while I work. Some of the short post I do is while I'm driving to the next client, and I know that dangerious but its still fun.hehehehe
RobosapienV2-4mem8
Yes it is a surprise to hear you are using assembly GW, I must not have been paying attention. So you are going to use some pics? What type? I may need to get some if I am to follow your code for Elvinator! Is there a special program for pasting assembly into Gw?. Laptop is working well, Just need to plug in some more periphials like my usb Hdd for photo storage and files, If I get a chance I will start a gallery.
I havent picked my PIC yet, I'm still looking around for the most I/O pins and how much EEprom memory I can use with it. The Elvinator code that I have right now is 95% full on the BS2 and all Data memory is full, This is one reason why I'm using the BSp40 and PIC chips. as of the coding being sent to the PIC there is another compiler that needs to be used and I'll make the jumper programming board for that instead of buying one. I can't think of the names right now of the compilers but I'll get back to ya on that.
RobosapienV2-4mem8
Cool GW, Nice to start acquiring parts and compilers for  later use.
Add a clyon eye to your projects. here is the code for using 10 leds and connect them to a 220 ohm resistor to pin 0 - 9: enjoy
' {$STAMP BS2}
' {$PBASIC 2.5}
'Cylon Eye - this program will scan 10 Led
' connect 10 LED starting at pin 0 to 9 with a 220 ohm resistor
' variables
Direction VAR Byte
LSB PIN 0  'least sigificant led bit
MSB PIN 9  ' most significant led bit
'init
OUTS = %1111111110 'make all the led pins an output
DIRS = %1111111111
Direction = 0
' start running up the leds
DO
  IF (Direction =0) THEN
    OUTS = OUTS << 1 +1 'shift the led up by 1
    IF (MSB =0) THEN
      Direction = 1 'change direction of led travel
    ENDIF
    ELSE
      OUTS = OUTS >> 1 'shift led down
      MSB = 1 'make sure MSB bit is set
      IF (LSB = 0) THEN
         Direction = 0
      ENDIF
  ENDIF
   PAUSE 100 ' takes 1 sec to run across 10 leds
LOOP
RobosapienV2-4mem8
These damn opto couplers are doing my head in, This should be the easy part, but for some reason they are not playing ball, I have tried 4N33, 4N25 and H111A And none want to work as they are supposed to. Looks like this is going to hold me up for a while compleating this H-bridge.
Stay in there and I'll get you going.
After a lot of circuit testing and code running the EAAR "Elvis Always Alive Remote" is finnished. My Elvinator has been running this program for 2 day straight and has never shut down. So I will now present you with the simple code that ran me crazy in circles. I'll post an article on showing you how to duplicate the remote. And now heres the program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' WowWee's Elvis Alive Always Alive Remote EAAR
' designed for dontknowdiddly at www.robocommunity.com
' by: GWJax Started: May 15, 2008 Completed: June 6, 2008
' Set pin functions
Play PIN 0 ' play audio
SongOrSpeak PIN 1 ' shift from audio to speak
NextSC PIN 2 ' shift to next song or comments
'set varaibles
TimeHold VAR Word ' Used for pausing the program
I VAR Byte ' counter
' Initalize Varables
LOW Play 'set pin low
LOW SongOrSpeak 'set pin low
LOW NextSC 'set pin low
TimeHold = 60000 ' hold time for 1 min
PAUSE TimeHold / 2 'pause for 1/2 min before starting program
' main routine
Main:
GOSUB Song
GOSUB Talk_Song ' change to talking mode
GOSUB ChangeSC ' play comment
GOSUB Hold2
GOSUB Hold2
GOSUB Hold ' wait in alive mode for 4 min
GOSUB Talk_Song ' change to song mode
GOSUB ChangeSC 'change Song and get ready for next song to be played
GOTO Main ' Start all over
Talk_Song: ' routine for changing for fron Singing to Commenting
HIGH SongOrSpeak ' press talk/song key
PAUSE 200 ' hold for 200 ms
LOW SongOrSpeak ' release button
PAUSE 8000 ' wait for 8 sec to finnish saying its command
RETURN ' Return to the calling routine
Song: ' Play a song
HIGH Play ' Press the Play/Pause button
PAUSE 200 ' hold down the play button for 200 m/s
LOW Play ' release the play button
PAUSE TimeHold / 2
PAUSE TimeHold ' Pause for 1 1/2 min to let song complete
RETURN ' Return to calling routine
ChangeSC:
HIGH NEXTSC ' play next Comment or change next song
PAUSE 200 ' Pause for 200 ms
LOW NextSC ' release the button
PAUSE 1000 ' Hold for 1 sec.
RETURN
Talk:
PAUSE 1000 ' wait 1 sec before pressing the play/pause button
HIGH Play ' press button
PAUSE 200 ' hold it for 200 ms
LOW play ' release Button
PAUSE TimeHold 'hold for 1 min.
PAUSE TimeHold / 2 ' hold another 1/2 min
RETURN ' return to calling routine
Hold: ' Hold routine for Alive Mode for 4 min.
FOR I = 1 to 4
PAUSE HoldTime
NEXT
RETURN
Hold2:
FOR i = 1 TO 3 ' hold for 1 1/2 min
PAUSE timehold / 2
NEXT
RETURN
RobosapienV2-4mem8
Nice job GW, perseverance has paid off, I knew you would resolve it.
It feel good to have this remote under my belt and now I can go back on the wall-e project to get it ready, which I think you'll be happy to hear. I have another voice changer tha records and playback with a warping wound, I'm going to try to hack this and get rid of the recorder and use the warping sound to fine turn the Wall-E voice, but I keep you informed on this new devise which is very small since space is like gold in him.
RobosapienV2-4mem8
GW, is this what you have sent me or is this something different you are experimenting with? Sounds [pardon the pun] interesting.
Ha ha, no I have not sent you this module. If it works, then we'll use both units, the one I sent you plus the one I'm working on or I should say testing with. I bought this module after I sent your package.
