Interfacing Different Robot Parts with I2C !
Maxiboy297
Maxiboy297's picture
I have a LEGO Mindstorm NXT and I am bored with only having the sensors released by LEGO . I am sure many owners will agree . This Forum is for discussing which sensors are compatible with the NXT and RIS 2.0
NanoTek
NanoTek's picture
Comment removed as it no longer applies.
The book you need is Extreme NXT Extending the LEGO MINDSTORMS NXT to the Next Level. This book takes you above and beyond what the brick can do plus adding other electronic sensors, motors, lamps and using the I2C for adding an additional 8 i/o ports. Using I2C feature as you may know that NTX-G does not support, so you will need to get NCB for the programming.
Hope this helps you out.
