The Rovio Master Mod
15 posts / 0 new
Thel
Thel's picture
For today I’ve gone out and taken steps to give our future robot masters one more way to assert control swiftly and painlessly.  In this case my Rovio can control anything that plug's into the wall.  I'm using a lamp right now for fun, but I think when I go out of town I might add some speakers to.
 The just of the mod is that I've set it up so that when I turn on the head lamp using the web controls, an electrical control box with say a lamp plugged in is turned on or off.  After it comes on I turn the lamp off or it will drain the transmitter.  Then when I turn the LED on again the lamp gets turned off at the wall.
 For this mod you will need:
                    A Key chain type wireless controller
                    A Low voltage Relay, I used a 5 V DC relay
                    Some soldering tools, wire and associated material
                    A PNP Transistor
                    A Screwdriver and pair of Wire Cutters
Here what you have to do.
       ----Disconnect Rovio's Battery before starting----
       You will need to open your Rovio up there are 6 screws around the bottom side.
       Once inside locate the headlight mounting bracket on the front to the bottom half of the case.  It comes off by removing 2 screws.  Once it is off, separate the the mount and the board by removing a further 2 screws
       Locate and disconnect the white wire leading to the LED.  Be careful leave all of the colored wires as they are.  Once the wire is free reassemble and mount the headlamp assembly as this is part of the auto pilot function of the Rovio.
        Connect the white wire to you Transistors Base pin and set aside.
        You will now need to tap off of the battery to run the relay.  A relay being a way for one electrical thing to control a different electrical thing and keep there power or in this case batteries separated.  You may choose a different method but here is mine
       I followed the large red and black wire from the battery to the power board on the right side of the case.  Then I removed the 2 screws at the top of the board and pulled it up to examine it.  What I found was that there are three pads with penetrations on the board.  The Pad in the lower left hand corner of the pad was connected to the red or positive line.  And the pad directly to the right of the black or negative line was tied to the black line.
        I soldered 2 wires, one to each pad and tagged them as two with polarity they where.  I then remounted the board leaving the wired hanging out.
             Next you will be attaching the relay to the Transistor and the battery.
       To do this solder the red battery wire you made to the transistor on the "Collector" pin
       Solder a piece of wire between the Transistors "Emitter" pin and one of the Relay's two coil pins.  I used about 6 inches
       Finally solder your black power wire to the other Relay coil pin.
        The last part electrically is wiring the relay to the remote.  This is pretty strait forward so you can do it how ever you like.  The just is that you pull the guts out of the remote and remove the button from the remote's board.  Then you solder 2 wires into the two spots the button went to and solder those 2 wires to the Common and Normally Open pins on the relay.
If you are working with a really with 4 pins instead of 5 just use the two pins that aren’t coil or control pins.
  That’s it.  Now all you have to do is with the parts in the case. I trimmed the remotes housing and zip tied it to the power board and found spaces for the other components where I could.  Just make sure to heat shrink all your wire and make sure that the remote board doesn't touch any other boards.   You may need to put insulation around the remote's board. Then just seal it up and turn her on.
----------------(Revision)-------------------
I've Think that there’s some backing up of power.  Mostly in my head but to be safe I've made a small change.  I've run a wire back to the headlight with a resistor.
         To do this   you will need to do 3 things
        -Attach a wire to the vacated space on the LED board
        -Solder a small resistor 1 to 5 ohms to the end of the wire and heat shrink the solder and exposed wire.
        -Solder the other end in line with the white wire making a Y.  So you should have the Base pin, the white wire that originally went to the LED and the remaining side of the resistor all joined.
 You may need to use small sections of wire, just use your best judgment on the how.  I can't be sure but I think I was getting a drop out in the camera so this revision will dump any voltage leakage when the LED is off.
The revsion
The Wiring
 The Remote and Reciver
The Remote open, Pre modifed
The remote with it's buttone removed by heating the solder and pulling.  Seen now with the wires that will lead to the Relay
 The Remote and the Relay
The headlight board on the front of rovio with the white wire cut free.  The white wire seen front will go to the trasistor and resistor I made the wire come together in a Y and heatshrinked pretty much everything
The Power board note the 2 clusters of holes in the lower left
Everythings is back inplace ans zip tied down.  You can see the body of the remote at teh top of the picture or on the right side of Rovio straped to the power board.   Its cut up to fit while still leaving plastic between the remote and the power board.  Alway have to much wire so you can fit components where  they don't get into moving parts or anything else.
Absolutely ingenious mod. Awesome! Is there a way to power the transmitter by the rovio battery? This is WAY better than the "official fix" for the rovio owners that hack.
Thel
Thel's picture
Actuly yes you can power it from onboard the only resone I didn't is that the tansminter I bought turned out to need a 12V odd ball and the onboard is only 6.  you can work around that with a small transformer but ya.  I'm lazy?
If you get a trasminter that is powered with less then six just add a resistor.
using Ohms law you can tell what tansistor to put between the Rovio battery and the remote.  E*R=I SO  Volts * Amps = Ohms  well kinda but  what it means is that you take what you have volts wise 6 and divide it by what you need
so say a 3v remote   6/3=2ohms  and you just take 2 more wires off the Rovio power board and and run the black one strait to the battery input of your remote and then run the other threw the resistor then form the other side of the resistor to the red/positive input on the remote
Be sure to check out my Auto Mag lighting mod.  if your feeling adventurous you can use a resistor the same way to power the mag light
Peter Redmer's picture
I really love this mod, Thel - this is a very unique way to hack the Rovio. I'm going to turn this thread into an article for the site that will be credited to you, I hope you don't mind :) That way more members can see this awesome hack! You'll see it on the homepage when it's complete.
Thel
Thel's picture
^.^ ya go for it let me know if you have any questions?!!!, and thank you :D
This hack can be turn to almost anything that uses a button or a switch. some of the easyer alternitives would be to get say a mirco tv remote. you can set it to hit the power button on the tv by wireing the relay to the power button. then detach the IR LED and stick it in one of the blue light holders with 2 wire going back to the remote board. If any one has a sugestion I'd be more then happy to try to work out the details for you :D
Thel
Thel's picture
Is that any chance I can get a hold of the manufacturer and make of the Rovio camra, maybe the manutatures literature? I'm 99% sure I can use the Master Mod to give Rovio to camra feed the norman one and say a low light black and white, similar to nightvision. Or jsut a look back feed for backin up.
Please let my know if any one can get me some hard data. I'd love to try it.
Thel
Thel's picture
Deleted by me
Thel
Thel's picture
Deleted by me
cimplexsounds
cimplexsounds's picture
Very cool! please keep us up to date on your progress.
jpkira
jpkira's picture
this looks like a great way to drain the rovio battery even quicker than it already does. INGENIOUS!
jpkira, it does not run off the rovio battery. This mod has its own power source. It wouldn't be hard to run this mod off the rovio battery which would not cause a drain since it is used only momentarily for only a few brief seconds. A running LED mod would use more power I think.
Thel
Thel's picture
Well now lets be not that witch we fear to be a mistake in another. JPikra the only time this mod draws off of Rovios main supply is when you activate the original LED.
To operate you flash you Original LED (on) then (off) you then leave the LED off until you want the remote device shut down. Again it will be (on) then (off) as fast as you like.
But yes if you use this and say turn the LED on it will draw power the whole time. And yes it will draw more power per unit of time. Those buttons on the operatorÂ’s page can be confusing I for one forget witch color means the LED is on alot.
If your worried though I can share a mod thatÂ’s is a simple but beautiful way to use a mini maglight. It's completely free of the internal power using it's own AA's I recommend the LED Mini mag cause it lasts forever on a pair.
The mag mod uses the positioning of the neck for on and off.
brokenai47
brokenai47's picture
sir, this is awesome. What a crafty fix :D
Maxhirez
Maxhirez's picture
Very cool. Has anyone tried rigging up a taser with one of these yet?
peterpan0205
peterpan0205's picture
