Replacing battery casing
6 posts / 0 new
SheBot
SheBot's picture
My recently arrived RSMedia, had dead batteries left in it. They have rusted & the springs have rusted & broken off. I have new springs to fit, but would like to remove the whole casing to inspect & replace parts as needed.  I see there is a screw deep inside the foot accessed near the toe.  Where can I find  details on dismantelling an RSM 's feet?
Thanks, appreciate any assistance .....
Hello SheBot, welcome to the forum! I've taken the foot shells off quite a few times and will be doing it again tomorrow sometime. It's a matter of carefully removing the 2 deeply inset screws as not to strip them and the other 2 screws above are more simple. There are also two small screws on the inside center "ankle". Hope that helps as far as the foot shells. Removing the battery cases is a bit more to do, I'll try to take some pictures tomorrow to help out.
SheBot
SheBot's picture
Thanks I found some pics on the RS Media Robot Disassembly, very helpful. Will take another look, helps to have the right tools.
Hi SheBot, I forgot to mention one of my favorite members here, TikaC, has documented here http://www.robocommunity.com/forum/thread/17779/RS-Media-Disassembly-Doc... Maybe those are the picture you mentioned. Oh and yes, be sure to use the right tools, stripping one of those deeply inset screws could turn out to be a nightmare.
SheBot
SheBot's picture
Hi Freddy, Yes that's where I found the info. I also found the Femisapien manual, as the one I rec with EMA was written in Japanese. Thank you contributors to RoboCommunity.
Shebot, be sure to post your finished fix! I'd like to see how it turns out. I received a RSM from the UK that came with an exploded AA. I used baking soda and water to clean it up. Yours looks tragic.
I have two femisapiens and I did the led eyes mod on them so they are surgically augmented you could say in human terms ha ha. Is your EMA details red?
