Has anyone done this? I'm familiar with LIPO's since I'm into RC aircraft. I can do very basic soldering, but nothing advanced.
Can anyone help so I can modify? I would think a 2 cell lipo would be ok, but someone please confirm that the roboquad runs at approximately 6 volts (LIPO is 7.1-7.3 volts 2 cell fully charged). Does anyone know if the slightly higher voltage is ok?
Ultimately it would be cool if I could make something that drops into the existing battery compartment rather than try to hard wire it to the roboquad.
Thanks!
I wouldn't push the voltage that high. You could use an lm317 to drop it down though
Cuidado, porque maneja dos voltajes, al parecer 3v para electrónica y 6v para motores, checale antes
I think the voltage should be kept low at times to avoid any deformities. It should be asked to the expert what will be the maximum amount.
vente maison royan
