is this correct
12 posts / 0 new
is this correct
vergot one thing,gerber is this corect.color adjust
On the reverse side of the chip you have it should have (TX) (RX) (VCC or ground)these are the connections you need to use. If you follow the notes as per the thread
http://www.robocommunity.com/article/13016/Connecting-to-the-RS-Media-Li...
This Thread also may help you as well
http://www.robocommunity.com/forum/thread/17944/-Solved-HELP-RS-Media-st...
Hi Nomad,
This module is called "USB to TTL". Usually TTL means 5V. RSMedia com port is 3.3 volts.
Some modules can do 3.3 and 5V. Can yours?
If Yes then change it to 3.3 volts
If No then this one may not work with RSMedia :-(
mine is 3.3 v
nomad said: mine is 3.3 v
Great! It will work OK with RSMedia then.
your right 3.3 v
rst
txd
gnd
+5v
i check it again
Hi Nomad
Below is a picture of the chip you have ordered from both side.
You wont need to use the 3.3v pin or 5v pin as the power comes from the USB on the computer. the only 3 pins you will be using are the RX TX and GND which are connected to the RS media serial hack below are the pin connects
(The chip) GND ------>6 pin  (Robot serial hack)
(The chip) TX  ------>2 pin  (Robot serial hack)
(The chip) RX ------>3 pin  (Robot serial hack)
below is a picture to show you this from Jamies post on the following thread
http://www.robocommunity.com/forum/thread/17944/-Solved-HELP-RS-Media-stuck-a...
Hope this helps you
yes if got the good one.thanks for the pictures
Jamie
Jamie's picture
Hi everyone, I haven't been on the forums for ages! Looks like everything is good, and Gerber's RSMCS looks brilliant!
Curtainmaker
Curtainmaker's picture
Hi Jamie
Hows it going. Its good to see you back again. I have missed your comments
Curtainmaker
Jamie
Jamie's picture
Hi Curtainmaker, things are good. I am home sick for the second day today. Thank you
Curtainmaker
Hi Jamie
well I hope you are getting better. Looks like a bit of computer rnr
Curtainmaker
