New Personality Problem
5 posts / 0 new
Strebor_
Strebor_'s picture
I am making a personality named 'SheBot' (name could change)
I have the 'PERSINTRO' in the 'Sounds' folder as an mp3 but when I select the SheBot personality, the intro is at least 5 times the speed it should be. She sounds like a demented Smurf.
Does anybody know why ? Or how I could rectify this ?
Thanks in advance.
Hi Stebor_, I did a search for demented smurf and found nothing but a chipmunk search found this. http://www.robocommunity.com/forum/thread/15044/Personality-MP3s-sound-l... there is the key regarding the sample rate and using stereo mp3 not mono.
Strebor_
Strebor_'s picture
FreddyA said: Hi Stebor_, I did a search for demented smurf and found nothing but a chipmunk search found this. http://www.robocommunity.com/forum/thread/15044/Personality-MP3s-sound-like-c... there is the key regarding the sample rate and using stereo mp3 not mono. Freddy
Thanks FreddyA.
I'll see if I can sort the problem out.
Hi Strebor
If it helps you could use my RS Media Control Station software to create the voices for you robot personality. It is available from the download section of this website. This automatically outputs the correct format for the robot and should sort out the problem you are have. Hope this helps.
Strebor_
Strebor_'s picture
gerber said: Hi Strebor If it helps you could use my RS Media Control Station software to create the voices for you robot personality. It is available from the download section of this website. This automatically outputs the correct format for the robot and should sort out the problem you are have. Hope this helps. Cheers Gerber
Ah great.
Thanks a lot gerber.
