connection bluetooth
6 posts / 0 new
hi all.am trying to make a connection whit the bluetooth and gerber rsmv4
i using anycom 2.0 bluetooth adapter.how do change the baud to 115200
thank you
You use the USB ttl chip conected to tx, rx and vcc on the bluetooth (outside of robot not connected). After you use teraterm to connect to the usbttl com port. Then you send AT commands to set your speed. Im not sure what AT commands you need so read your bluetooth instructions to see what AT command you need to send. Most times its best to copy and paste the commnd to the teraterm as typing wont work too well. ALSO some chips are already set to 115200 so read your bluetooth instructions to see what the default speed is set already.
when the bluetooth is connect ,the led chould flikker or lid up constantly.thx
My bluetooth does not have any lights, but gerbers does have I remember. I think if your lights flicker then probably sending tx data!
Hi Freddy/Nomad
I have put instruction with the screen shot of how to program the Blutooth chip on my site www.themadrobot.talktalk.net The command I used to the the blutooth chip was AT+BAUD8
Hi gerber, thats a really great write up on how to do all the serial hack. Ill keep that in my bookmarks!
