connection via ip adres windows xp
1 post / 0 new
hi all.for those who have xp windows.
1-open control panel and choose phone and modems
2-choose modems
3-add and click on don't deteckt choose from list
4- choose communication between two computers ( no com port yet now )
5-click next and choose com mine is 4
6-click next and finiche
7-open control panel and choose new incomming connection
8-choose advanced and click next
9-choose directly to oher computer and click next
10-choose host and click next
11-now you choose your com port,it will be shown in the down drop list,
12-wait when it show up and click ok
13-click on incomming you made and choose properties
14-choose general and take communucation between two computers , choose properties
15-choose allow callers to accses my local area network
15a-choose specify tcp/ip addreses
15b-from 10.0.0.1
15c-to 10.0.0.2
15d-total 2 and click ok
16-now choose users next to general and set the baud speed to 115200
16a-and below hardware none and click ok
17-now choose general back and uncheck communication between two computers
17a-and click ok
18-click on incomming again ,you see the uncheck again,don't do anything now
19-now boot your rsm check the communication on set baud speed and hardware none
20-click ok and click again on empty spot on the sreen so the blue color go's out
21-now wait the second incomming chould show up in a few seconds
22-when it does you have ppp or connection via ip adres.
23-open gerbers program and set your com port number
24-choose ip and set 10.0.02 and now connect the rsm
25-the color will change into green you got ppp
 good order to open this connection is this
1-boot up your computer
2-let it do his normal thing
3-go to new incomming connection cause it will not be there ,it dissepears when you
3a-chutt off your computer.so you have to make it back everytime,only this connection
3b-starting by make new incomming and do the steps like i writen ubove
3c-this is a good thing to do when you want to work whit rsm,always make first the
  the incomming connection reddy,when you do this several times,it go fast.
  like rsm would say ,cut thats a wrap.have fun all
