RS Media Video Ribbon Cable
7 posts / 0 new
r_wright1
r_wright1's picture
I need to repair the end of the video ribbon cable that attaches to the media board.  Replacements don't seem to be readily avaiable, so I want to trim off the small end damage and use the existing cable.  My question is - what is the best method to remove the plastic coating on the cable to expose the metal within the ribbon cable?
do you have pic.i think these are to get
R-wright1, here is a picture of the ribbon cable where I scraped to the metal. I used n exacto knife just started at one point and continied scraping till i see the first trace. http://www.robocommunity.com/forum/thread/17432/Please-help-RS-Media-Boo...
r_wright1
r_wright1's picture
Thanks for the link FreddyA, looks easy enough so I will give it a try. I have found this 18 pin cable on E-Bay in shorter lenghts. I noticed you mentioned in that link you soldered a ribbon cable, do you think it is it possible to solder two cables together to create a single long cable or is it more trouble than its worth? I did e-mail the seller to see if he has these cables in a longer lenght (around 30cm or 12in) but I have not heard back from them yet.
r_wright1
r_wright1's picture
Thanks for the links, but I am looking for the video display cable which is 18 pin and around 30cm or 12in long. If anyone has a source for that, I would appreciate it.
