does the sharper image edition of robosapien v2 have bad wiring insulation problem.
11 posts / 0 new
Moosa farhan
Moosa farhan's picture
woowoorobotic 12
woowoorobotic 12's picture
Hi Moosa Farhan,
Almost all the robosapien V2 have wiring problems and that's probably why its discontinued.
TehRSV2
TehRSV2's picture
They all do. Some say certain models are less likely to have it but it's nothing but a rumor. As mentioned above, this is why the RSV2 was recalled.
Moosa farhan
Okay thanks
you can check this in the feet.in the foot is a tiny circuitboard,the good one,
have connectors there.the bad one are just soldered there.
Giollachriost
Giollachriost's picture
I did not know about the connector difference, Nomad. I am going to try to put this to use and look for another V2. Thanks for the tip!
your welkom
Moosa farhan
Thank you for your replies but there is another rumor that the black robosapien v2 does not have that bad wiring insolation problem is it true or false
Giollachriost
You should notice Nomad's advice about the connectors in the feet. All V2s were apparently constructed in the same factory but different production runs followed with different production supplies and standards. Good luck!
checking the wires whit the chest open.takes maybe 15 min.
there a video on youtube type in.robosapien v2 fire hazard.
the video gif an idea why you MUST check your wires.
Redcoolxmaster
Redcoolxmaster's picture
Jobean Vids say that the black has thick wires unlike the white one
