Help for Develop RS Media
8 posts / 0 new
Tareq
Tareq's picture
I am new for Developing Applications for rs media ,I have some Questions : 1- Is there a way to develop an application for RS Media using .NET?2- I want to Excecute a program at RS Media But not By RS Media Development kit because it use the SDcard which is an old and small storage.3- Is there is better way to interact with the robot better than IR remote ? 4 - Can I connect /replace the Processor by another enhanced one ? or plug a Pocket PC like RoboMe ..I think the Best thing in RS MEDIA than ROBOMe is it has alot of motors .. so I want to use something like that (without hurting the head ) and with total control it by My c# code or c++.
Tareq
Tareq's picture
Thank you for care and help,
I checked the RS Media Develuopment kit
http://sourceforge.net/projects/rsmediadevkit/files/?source=navbar
I liked some of them like :
CopyBot ( I read the documentation it says that it include the source code , but in fact I didn't find it .., do you have its link.
2- If I used the USBNET way then I'll not open the robot and hack it's motherboard right?
3- I read in one thread that you says there is a way to control it using wifi
http://www.robocommunity.com/forum/thread/20308/newish-RSM-hacks/
how to?
What is the combonents needed : because I search on the internet I found many USB to Wifi , but it seems it convert the computer's usb , I want the robot to send ,
computer recieve and computer send , robot receive.
What is needed and software to use it ?
Tareq
Tareq's picture
So USB cable allows rs media to transfer files b/w pc and Rs Media but not control it and send commands and execute programs/commands,
like this article says :
http://rsmediadevkit.sourceforge.net/usb_console.html
Right ?
so even if I made this so I have to hack it by serial port to control it right ?
Tareq
Tareq's picture
Okay sir so I a agree and I decide to hack it by using serial way:
do you have a simplist and step by step with Pictures and videos how to do it ,
because I see some but they was not clear and was not all of them loaded fine
Also I want a Hello world program or anything I can try this with a code I can run by myself..,
I'm sorry about that but I want to start from a long time ago but I was afraid before I meet you :)
Tareq
Tareq's picture
I downloaded Unix and setup it
Now I want to control it using blutooth , or if it hard by serial .
and make my own program , I can buy from radioshack anything simple please
Because I don't know electronic
I need to know exactly what to buy by picture?
How to plug it?
I purchased usb to serial cable (female usb for computer and male serial ) is this what you mean?
Tareq
Tareq's picture
I found the way to open and items to connect by Bluetooth ( I hope it will work fine)
Do you have an example for code and libs to can execute on the RS Media using serial Bluetooth ?
Is it deferent than wire Serial for programming ?
what is the tools needed ?
In the past I Used the Java development kit using the SD card , now I want to use the Bluetooth I will plug in.
thanks.
Hi Tareg
You can find a instruction how to do the serial hack on my website including the bluetooth connection method.
http://madrobots.wix.com/themadrobot#!rsmedia/c18xa
Here is a direct link to download the instruction document:
http://sourceforge.net/projects/themadrobot/files/Robot-Resource/RSM-Software/Instruction-to-setup-communication-to-the-RS-Media.zip/download
Hope this helps
Gareth
Tareq
Tareq's picture
Great ,
Thanks Gerber,
I made the above , thank you very much :)
I want to write my hello world program using this hack with the simplest way.
* What is the Tools.
* Development environment.
* Access the port mentioned in the tutorial.
* Control the motors .
