Roboboa gears??? What's this??
7 posts / 0 new
StickMan
StickMan's picture
Roboboa stopped supporting its weight from the middle body section.
Undone the casing retaining screws & found this laying loose...??
Any ideas what it is & where it should go??
All help greatly appreciated.
nothing to see inside the case you unscrew.?
StickMan
StickMan's picture
Nothing to see???
That white circle piece is just floating around in the casing - shouldn't it be attached to something?
Does any one know what this loose white piece is?
it looks like a part to keep some wires separeted.
does fit it in the hole on your right side?
picture 14
french friend
french friend's picture
This part have to be placed on the axel of cover passing though the motor. It is used to maintain wires and avoid any trouble with cover while closing it. It is located in the hole you may find on the right bottom part on your picture. Not easy to place it, but can be done with patience.
