Not running forward and backward flexing. Help
8 posts / 0 new
Wiktor_B
Wiktor_B's picture
I suspect that the control board is broken. where to buy?
Wiktor_B
Wiktor_B's picture
Forgive me if I write incomprehensible. I use a translator.
Board motors I checked. All is good. Verifies the connection channel to channel CHEST BODY. CHEST channel on-board motors running. Firmware can be damaged?
What is SPBA01A? There documentation SPBA01A?
Wiktor_B
Wiktor_B's picture
I broke the motherboard. Where can I buy a motherboard?
they are very hard to find.mostly you need a second one.here is a link you can try.
http://www.benl.ebay.be/itm/171274593414?ssPageName=STRK:MEWAX:VRI&_trks...
Wiktor_B
Wiktor_B's picture
nomad said: they are very hard to find.mostly you need a second one.here is a link you can try. http://www.benl.ebay.be/itm/171274593414?ssPageName=STRK:MEWAX:VRI&_trksid=p3...
Too much. In Russia will not send.
ah sorry
Wiktor_B
Wiktor_B's picture
crazygeorge said: hi how is it broken ? ( any pics ), Privet, kak doska slomalas', dvigatel' doska, osnovnuyu platu , chto dvigatel' doska podklyuchayetsya k , ili sovet SMI , ( on imeyet raz"yem dlya karty na ) . Vy budete borot'sya s pokupkoy zapchastey , no bol'shinstvo componants by de- payke i smennyy �?�?иве�?, как до�?ка �?ломала�?�?, двига�?ел�? до�?ка, о�?новн�?�? пла�?�?, �?�?о двига�?ел�? до�?ка подкл�?�?ае�?�?�? к, или �?ове�? С�?�?, (он имее�? �?аз�?ем дл�? ка�?�?�? на). �?�? б�?де�?е бо�?о�?�?�?�? �? пок�?пкой зап�?а�?�?ей, но бол�?�?ин�?�?во componants б�? де-пайке и �?менн�?й.
I swapped the SPBA01A.
Now the head turns to the left. Can not stop. Probably burned SPBA01A.
Ne ponjal pro zapchasti.
Wiktor_B
Wiktor_B's picture
No. The robot is not loaded. Begins to turn your head to the left. Limiter does not work. Starts to click. Do you understand Russian?
