PC based Robosapien control
15 posts / 0 new
Meenzal
Meenzal's picture
In the Robosapien Companion the author made a reference to software to control RSV1. I've seen links all over the web for the PC based Robosapien controller. Robots Dreams has an article from the author that goes on and on about it, but I'll be darned if I can find this software anywhere. Did this ever get built and released or was it just a good idea that never got past talking?
Sylux
Sylux's picture
I think it is Robodance.
Meenzal
Meenzal's picture
No, it in't robodance. I have that. This was like PC Commander or something like that.
samredelf
samredelf's picture
oooh! Do please let me know if you found anything. I would love that for sure.
Meenzal
Meenzal's picture
HAH! I found it again. It was over on robots dreams.
http://www.robots-dreams.com/2005/03/developing_a_pc.html
After finding this, I went hunting again for info on availability but was again frustrated. It looks pretty nifty, but it appears that so far, all the guy has is a pretty JPEG of what he wants the interface to look like. Considering that even that is 5 years old, I don't hold out a lot of hope.
A_Geek
A_Geek's picture
Sapienx works from the command line if that helps any... I used it to interface my V1 to my home automation PC. :)
http://www.robotika.sk/mains.php?page=/projects/robsapien/
Hope this is useful!
coredump9
coredump9's picture
I created a Python program called RoboMoco (Robosapien Motion Compiler) that allows you to control a Robosapien from your computer via serial port. You can send either the raw bytecodes or macros to make your bot perform complex action sequences.
In my setup, I use an Arduino as a "middleman" between the computer and the Robosapien. But you may be able to use the program with minor changes to make it work with an Lego IR-Tower so any hardware that behaves like a serial device.
RoboMoco: http://borglabs.com/projects/robosapien-v2/using_robomoco
My Project: http://borglabs.com/projects/robosapien-v2/arduino_serial_interface
Hello coredump9, welcome to the forum. RoboMoco sounds very cool. I am excited to read about the info on the hardware hook up. Keep us up to date.
Meenzal
Meenzal's picture
Hey, has there been anymore info on Robodance 5? Last I heard it was due in summer but got pushed to September. I'm on the notification list, but no words since the last postponement.
I'm glad to see that people are still out there developing robotic control methods for PCs. Good job, coredump9!!
The Arduino is for controlling non-IR based bots like Wowwee I assume?
coredump9
coredump9's picture
Hi Freddy and Meenza,
thanks for the warm welcome and kind words.
The Arduino basically allows you to control the robot either by computer (commands are sent via a serial port) or by the IR remote controller that comes with the Wowwee robots. I cut off the wire inside my Robosapien V2 that receives the commands from the IR remote and sends the pulses to the robot's motor board. Then I put the Arduino in between the two ends of the cut wire, so that the Arduino intercepts the IR commands and relays it to the motor board. I will try to post info on the hardware setup in the next couple of days to make this more clear.
Ben
coredump9
coredump9's picture
here's the info on the Arduino board hookup to the Robosapien V2.
http://borglabs.com/projects/robosapien-v2/connecting_the_arduino
enjoy,
Ben
Meenzal
Meenzal's picture
Ah, I did the same thing with a V1 and posted the process and photos here. I got the idea from a user here that had done it earlier. But you're the first to do it with a V2.
In mine, the Arduino also uses an IR range finder in his belly that allows me to use typical Arduino autonomy avoidance routines. I used an Ardunio Pro Mini so I could fit the whole thing inside the Robosapien so it didn't need a backpack as the original poster did. It looks stock.
It is still the white wire in the V2 the IR wire or did they change color? The V1 wire is white.
Still think it's way cool what you're doing. A few of us here are very much tinkerers like you! :-)
iamiane
iamiane's picture
hey coredump9, I had a robosapien v2 stashed in a cupboard and decided to give your project a go but the sit is down is there any chance you could send me the info?
jpdenoyer
Hello I'm a newbee to hacking robosapians. I do know alot about software and a little bit about hardware in general.I recently purchased both an original robosapian and a V2. I would like to add a board (either a raspberry pi or an arduino) with a microphone so as to make them voice controlled. My first though was to attach an infrared dongle to the raspberry pi and use robodance software. No one responded to a previous post requesting information about recomended brands for infrared dongles and/or microphones. Also my previous post asked about tutorials on kylix.I see a couple posters on this thread used an arduino and connected it directly to the brain thus bypassing the need for an IR dongle. Can I get any technical details and/or sample code. The supplied links are dead.Any other ideas on how to proceed?
ColinDavy
I am working on a program that allows you to control a Robosapien from your computer via serial port. You can send either the raw bytecodes or macros to makeyour bot perform complex action sequences.In my setup, I use an Arduino as a "middleman" between the computer and the Robosapien. But you may be able to use the program with minor changes to make it work with an Lego IR-Tower so any hardware that behaves like a serial device.
