The final Solution for Wowwee losing wifi / re-connect problem
25 posts / 0 new
hhspiny
hhspiny's picture
This has troubled me for a long time and even after a replacement. wifi looses connection after a peroid time of inactivity, typically in a few hours. The only way to re-connect it is to restart it. I have tried all possible suggestions I can find here and elsewhere, and nothing worked.
I decided that it has to be a hardware problem, most likely due to faulty wifi card. So I took it apart, find the model of wifi card, and bought one, replaced it. Now, the connection has been rocket solid for last week and I believe I finally solved the problem !!!
1. the wifi card is located in the head unit, right behind its camera. you only need to unscrew four screws on the back to get the cover off and you will see the wifi card. extremely easy
2. the wifi card is of a model MM200-M. I googled it and found it in www.pchub.com -- 802.11b/g PCI Express half-height mini card MM200-M. bought it for ~$10 including shipping, and it actually showed up in my doorstep in about a week shipped from singapor.
3. the wifi card is soldered to the circuit board on the opposite end of common pci slot. you will need to get your iron to get it off. which will take a bit of soldering skills but nothing special, just be careful and slow, remove one bit a time
4. finally, insert the new card in the pci slot, put solder the other end back. and you are all good to go.
I can't believe that Rovio used such low quality card that probably costs $5 to them in a toy sold for hundreds of dollars, and create such wide spread problem.
cowboyctx
cowboyctx's picture
Good job. Wonder if we could get a more expensive better quality card?
vinnie
vinnie's picture
I'm not sure what's up with this "fix" but I've found that having more than one device connected at one time can be bad. Always close your browser when you don't need to use the rovio.
ThoughtlessThinker
You have just saved me loads of time and effort. I bought a faulty Rovio via eBay. Turns out it cannot access WiFi at all (no adhoc even after hardware reset). Got it apart and found the wifi card (figured it could be damaged antenna lead or card connections. Thought I'd search the model number and presto, found this post! So I've wasted no time ordering a replacement card from PChub. Looks simple enough to replace. Thanks so much for taking the time and effort to write this up.
Waynosan
Waynosan's picture
Is this solution still solid for you? My Rovio has been dropping out also with similar to sympthoms as yours originally exhibited. I'm not really sure what to do to troubleshoot. Not sure if it's a WiFi board issue, my router, or just my setup somehow. I'm running firmware 5.03. Any suggestions?
Waynosan
Waynosan's picture
Is this solution still solid for you? My Rovio has been dropping out also with similar to symptoms as yours originally exhibited. I'm not really sure what to do to troubleshoot. Not sure if it's a WiFi board issue, my router, or just my setup somehow. I'm running firmware 5.03. Any suggestions?
Waynosan
Waynosan's picture
Just for everyone's info... the replacement WiFi boards the the OP linked to are super cheap right now and they have free shipping to the US. I ordered 2 and it was under $8 if I recall correctly.
snakerattle
Hi All
I have the same problem and ordered 2 wifi cards from the shoplink all OK.
Now i prepaired the new wifi mm200-m in my rovio and the Light goes orange and nothing more!
So I cant connect my rovio with all methods no chance,but when i Inserted the old wifi card rovio goes from Orange to Green and worked.
Can this be a Problem with the new mac adress that this modules have or are the 2 cards damaged?
Hopefully for your Answer Thanks Robert
vinnie
vinnie's picture
@snakerattle: try USB configuration after changing the card. MAC address does change so your WiFi router won't like Rovio until it is reconfigured.
snakerattle
@vinnie: Yes i did so at first time but when only the orange light is on i cant connect with the rovio setup and also the adhoc it doesnt work!
The new moduls have the same number and all looks like the same as the original
it seems there is no difference.
I thought i have no luck with them.
Kohlenklau
If you look at the item description at pchub.com you will realise that their MM200 wifi cards are used parts. I ordered 3 cards recently, one was faulty, wich gives you the solid orange light.
Anyway, the other two work well and solved the connection problems on two of my rovios.
So, to be on the safe side, buy some more cards (they are cheap!) - in the long run you will need them anyway.
Nng
Wish I'd read all the posts as I ordered just one card from pchub.com and it was faulty -- I swapped my original and the pchub one in and out several times just to make sure it wasn't me.
Fortuitously, it seems like just the act of unsoldering and swapping the card in and out seems to have fixed my disconnect problem!
Gnattycole
Gnattycole's picture
Just ordered 3 of these. Will keep you posted once they've arrived to see if it cures my issues.
Gnattycole
Gnattycole
Gnattycole
Gnattycole
Gnattycole
madhak
Anyone tried dual radio card? does that trick work with other card than the one suggested?
Thank you very much for this information!
gannboy
Hi guys,
I really needed some help here with my rovio...
I have read this thread, http://www.robocommunity.com/forum/thread/19172/Resurrecting-Rovio-A-Win...
and posted a reply too.
I have the following questions, hoping someone can kindly help me. Really appreciate it.
1) Will Rovio be able to work in Windows 7 x64bit system after I have successfully installed in Windows XP mode under Windows 7 x64bit system. I am using a PC rather than a laptop computer.
2) Or do I have continue run Rovio under Windows XP mode under Windows 7 x64bit system?
That's all for the moment.
Thank you.
Eddy
madhak
gannboy said: Hi guys, I really needed some help here with my rovio... I have read this thread, http://www.robocommunity.com/forum/thread/19172/Resurrecting-Rovio-A-Windows-... and posted a reply too. I have the following questions, hoping someone can kindly help me. Really appreciate it. 1) Will Rovio be able to work in Windows 7 x64bit system after I have successfully installed in Windows XP mode under Windows 7 x64bit system. I am using a PC rather than a laptop computer. 2) Or do I have continue run Rovio under Windows XP mode under Windows 7 x64bit system? That's all for the moment. Thank you. Eddy
I didn't got much luck setting up my rovio under Windows 7 64bit.... after installing the unsigned drivers in xp sp2 mode, my computer wouldn't boot anymore, had to do system restore to get rid of the drivers... I ended up powering an old pc I had lying around with windows xp to do the setup.
after that I was able to use my rovio on other non-xp computer, either trought the browser or RovioDirect software... Also using Roborealm but this one is a bit more complicated.
Roviodirect work really well for a free program, i'm using it on my windows 8 tablet and windows 7 x64 desktop
Good luck with the setup, its a shame they dont support this product anymore but once you pass the setup it should be easy to use on any system. If you dont have an XP computer, ask a firend or buy a 20$ laptop at a garage sale. I'm sure there is a way to install it on 7 x64 but I couldn't figure out and the post you refered to didn't worked for me. Make sure you create a restore point if you try it.
madhak
madhak said: Anyone tried dual radio card? does that trick work with other card than the one suggested? Thank you very much for this information!
In reply to my own question, I did try few other brand/model of wifi card of the same form factor and it did not worked. The wlan adapter drivers most likely need to be changed in the firmware... anyone managed to do that?
cowboycctx
cowboycctx's picture
The Rovio will work with Windows7 64 bit. You only need to use the XP mode to configure the Rovio.
Tareq
Tareq's picture
Dears :I tried the VMware Virtual Machine of Windows xp in Windows 7,8,10 but didnlt bass the step in installaton 3 :which is check the connection to the internet ! - the Internet connection is okay .- The router is WEP as the tutorial Say. -I cannot get the latest Firmeware and SDK wowwee Support site , It is down !I need the :- Last firmware Version- Last driver link - last SDK . * Can I use the rovio on other os like w10 ? I want to develop applications for it using VS.net 2013 and connect it to another robotics which not support the WindowsXP.* Is there any driver for W7,8,10? Thank you very much :)
Tareq
Tareq's picture
