Note: The RoboCommunity Webiste no longer accepts new users. Content is read only for historical purposes
Robosapien V2 Sound Not Working (Please Help)
12 posts / 0 new
Redcoolxmaster
Redcoolxmaster's picture
So the other day i got a robosapien v2 its fine and all that but when i play the sound wont come on i have tryed everything to fix it i might open it up but anything to help the robots sound come back on without taking it apart i love this robot.
I have also tryed putting new batteries in but it still wont work
Redcoolxmaster
Update: Still not working on sound
you can test the speaker whit a batterie.same volt as speaker.
see when it retracks when you connect the batterie on the speaker.
if he dont the speaker is dead.he must retrack ones.
Redcoolxmaster
Hi Nomad Thanks but I got another problem I don't know if this is normal or what but yea
So when my Robosapien walks it stops quickly and walks again it seems like its coming from one leg Then,when I lay him down and do the get up feature he is alright but it happens the next day again
Redcoolxmaster
I Don't think that's the problem
No affence
but it works fine after a bit but thanks anyways I might check
Redcoolxmaster
That's the walking
The sound speaker has blown out
i would check the wires as teh recomended anyway.
Redcoolxmaster
Its gone worse :( he is too weak to walk
get the batteries out before the circuitboards get damage.and check wires.
they are hard to find.
we teach you how to do it.
eniot94
eniot94's picture
Hi everybody (sory for my english I'm French),
I have a big problem with my speaker
but I don't know how to extract or test or change it.
What are the goods wires ?
Thank you for your help !
AlinaE
AlinaE's picture
Hola.... qué alegría encontrar este foro. Voy a ayudarles a averiguar cómo solucionar el problema de sonido del RS V2. Y de paso, aprovecho para comentarles qué problema tiene el mio. Inició diciendo que no tenía un buen motivador y ahora, inicia normal, se identifica pero luego dice: "necesito estar de pie para ejecutar esa acción" y no hace nada más. Está parado, pero cree que no. Si alguien me puede ayudar, lo agradecería infinitamente. Yo como ustedes, amo los robots y éste especialmente, porque es el que tengo. Muchas gracias y les escribiré lo que encuentre referente al problema de sonido. Alina
Error | robocommunity.com
Error
The website encountered an unexpected error. Please try again later.
